Online Now [302]:
Visitors: 301
Today: 52348
Total: 155150855
Forums › The Car › 206 Problems › strut brace boonet vent hole size
Neil206
PostPosted: Fri Aug 24, 2012 3:35 am Up
when fitting the front strutbrace, the size of the hole needed to be drilled in the drivers side air inlet square, under the rubber, and any other useful dimensions on where to drill it? cheers in advance
206
Neil206
PostPosted: Fri Aug 24, 2012 3:42 am Up
also any pics & looking at the omp one, i presume it doesnt matter what its listed as (sw / gti / hdi / cc, 1.6 etc), as i assume the 206 mounts / air inlet location didnt change in the cars whole production lifetime (my cars a 2001 (Y reg) 1.6 XSi)
206
PostPosted: Fri Aug 24, 2012 4:20 am Up
Have a look in the project threads. A quick search might throw up a few.
I know drunknmunky had some pictures of his on here and there will probably be others if you have a look.
PostPosted: Fri Aug 24, 2012 6:05 am Up
it does matter. as the coolant bottle are different shape.
