Posted: Thu Aug 23, 2012 6:23 pm |
Hi guys,
I'm struggling a little with changing the oil on my Pug... I can't find where the drain plug is located!
I've seen lots of pics of other engines and none seem similar to mine... I only see a plug that seems to go out with an allen key (on the back left side of the oil pan - as seen from the front), but it has no head like to use a 21mm socket (as I've seen in this forum most of the other models have).
Can anyone help? Pics are very much appreciated.
Regards!!
| Are we talking or are we racing...? | |
Posted: Thu Aug 23, 2012 8:48 pm |
You need to use the correct tool, not all oil drain bungs are hex headed
Posted: Fri Aug 24, 2012 2:45 am |
Would this engine have the square hole in the sump plug? The bodgers would use a 3/8 ratchet to get it out but you should really get the proper 8mm tool.
Posted: Fri Aug 24, 2012 3:20 am |
Aye, a drain plug set doesn't cost much and is better than bodging.
| Daily Hack - 2013 Audi A3 Sport | |
Posted: Fri Aug 24, 2012 11:26 am |
My TU3 lump needs the square key to remove the sump bung, the correct tool is cheap.
Posted: Fri Aug 24, 2012 11:40 am |
would be easier to drill the sump and then plug the hole back with a wine cork after the oil change
Posted: Fri Aug 24, 2012 11:47 am |
Seabook wrote: |
would be easier to drill the sump and then plug the hole back with a wine cork after the oil change |
Be easier to just swop the standard bung for the quick drain type, saves on drilling & no more tools needed to drain the oil
Posted: Fri Aug 24, 2012 11:59 am |
MrBSI wrote: |
Seabook wrote: |
Be easier to just swop the standard bung for the quick drain type, saves on drilling & no more tools needed to drain the oil |
i always though those thing would seized when ever you want to do the oil change
Posted: Sat Aug 25, 2012 4:16 pm |
macca1411 wrote: |
Yeah, it's exactly like that one. Thank you for your answers, I'll try to find the correct tool...
