Latest: sparrowdclxvi
Overall: 17139
Online Now [543]:
Visitors: 542
Today: 124811
Total: 112808685
Forums › The Car › 206 Problems › This normal(headlights)?
kurosagi01
PostPosted: Fri Aug 24, 2012 4:09 pm Up
So after switching over the black mask with orange and having the chrome finish with reflectors.
The visibility has improved but,this normal?
Apology with the poor images,but its only way to show it in dark.
If it isn't what might be problem?
Alignment completely off because of not properly sealed?
Fitting was done incorrectly?
Reflectors damaged?
Bulbs giving in?
PostPosted: Fri Aug 24, 2012 8:03 pm Up
So how is improving the 'visibility' a problem?
& you wrote an apology for the poor images, surely you meant English?
kurosagi01
PostPosted: Sat Aug 25, 2012 2:34 am Up
What I mean is it is an improvements from when I had the white reflectors and not the chrome installed.
DeadEyePaul
What?
He is asking if that beam reflector pattern should be like that?
PostPosted: Sat Aug 25, 2012 4:29 am Up
Was your levelling switch on '0' when you took the pictures?
You need to go to a garage and get the headlamps aligned. You could attempt it yourself against a wall but it's not as accurate as their machines. It's the sort of thing the apprentice can do and shouldn't cost that much as only a 5 minute job.
kurosagi01
PostPosted: Sat Aug 25, 2012 4:30 am Up
I just went to the garage,they say the alignment seems okay but the pattern really off. I will need wait until Monday for them to see if they can sort it out.
ukskater01
PostPosted: Sat Aug 25, 2012 5:36 am Up
As long as your adjusters work it should be a 5 minute job. I had a nightmare trying to free the inside of my headlights so they would move with my adjusters. Think someone tried to split them in the oven, gave up and sold them to me!
PostPosted: Sat Aug 25, 2012 5:42 am Up
Looks like the bulbs have been fitted upside down to me Wink
Plus the headlamp alignment needs checking / adjusting at an mot station.
PostPosted: Sat Aug 25, 2012 4:43 pm Up
What?
Congratulations on your superior grasp of chav English.
kurosagi01
PostPosted: Sun Aug 26, 2012 5:53 am Up
Okay i was a bit of a idiot i did have the bulbs upside down,so i flipped them over and definitely made slight improvements. However the pattern is still off,is the screw that adjust it the one next to the cables?
DeadEyePaul
PostPosted: Sun Aug 26, 2012 8:27 am Up
What?
Haha!
