Latest: sparrowdclxvi
Overall: 17139
Online Now [84]:
Visitors: 83
Today: 29099
Total: 113197814
Forums › The Car › 206 Talk › torsion bar help! someone must have some ideas!
Go to page Previous  1, 2
usher
PostPosted: Mon Aug 27, 2012 4:28 am Up
good advise there
it would be in a garage 1 if i could afford over 100 quid in labour and 2 no one in my area does it
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Mon Aug 27, 2012 1:18 pm Up
there out, new ones in only took 3 days
had to hit it from one side then the other to loosen it up with some wiggling and a can of wd40
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Mon Aug 27, 2012 2:04 pm Up
I hope they went in with lots of copper grease on the splines...
usher
PostPosted: Mon Aug 27, 2012 2:32 pm Up
certainly did as i need to car tomorrow so the height was guessed. turned out about 20mm higher than what it was.not sure weather i Will lower it more as yet as i liked it as it was.
think the height its at now is best for handling.
they made a nice improvement in feel from the back and make the car feel more solid
project thread WIP
garage
FAQ
206 gti firedance
nathdavies91
PostPosted: Wed Aug 29, 2012 4:29 pm Up
lots of good advice here guys! ill try some of it sometime when i get my car back from the garage!
PostPosted: Wed Aug 29, 2012 4:33 pm Up
i presume you fit the 22mm torsion bar?
that could be why it is higher than you would have though
usher
PostPosted: Thu Aug 30, 2012 1:51 am Up
yeah the 22mm ones i put in. i knew the back would raise a little with the new bars but think its also one spline higher.
look on my project just put up before and after pics
project thread WIP
garage
FAQ
206 gti firedance
Page 2 of 2
