Latest: heikkisj
Overall: 17126
Online Now [62]:
Visitors: 61
Today: 15388
Total: 100324736
Forums › The Car › 206 Problems › want to install LED STRIP on boot light not sure which +/-
heyziq
PostPosted: Mon Aug 27, 2012 3:03 pm Up
heyziq.com
heyziq
PostPosted: Mon Aug 27, 2012 3:07 pm Up
imageshack.us/photo/my...arlamp.jpg
heyziq.com
PostPosted: Mon Aug 27, 2012 3:10 pm Up
Black is positive
PostPosted: Mon Aug 27, 2012 10:53 pm Up
There is always the check it with a test light / test meter option Wink
PostPosted: Tue Aug 28, 2012 5:33 am Up
Remember the switch is after the lamp in the circuit.
If you connect to the live and then earth the light strip, it will drain your battery, if you connect in series it will only come on at half strength.
heyziq
PostPosted: Tue Aug 28, 2012 10:31 am Up
means if i connect led directly to the wire socket the light wont turn off when
close the boot?
heyziq.com
