Latest: jtq4u
Overall: 17141
Online Now [203]:
Visitors: 202
Today: 40427
Total: 113947492
Forums › The Car › 206 Problems › off side rear wheel leaning in!! :-( Advice needed
Go to page Previous  1, 2
Camm206
PostPosted: Sat Jul 07, 2012 12:39 pm Up
Hey guys thanks for the replies took to a mechanic friend of mine and he said replace the axle outright so your advice was right but there are a whole load of age related problems just adding up to more than the value of my car
1.4 8v, Slowly Getting There
weejoe86
PostPosted: Tue Aug 28, 2012 8:56 am Up
Sorry for the late reply and for reviving an old thread. There is no play I the arm but the wheel is now rubbing the inner arch when try to put my hand down the back of the wheel. So I think it more than likely must be he axle bearing. The only other think I've noticed is that there is movement in the tie bars with the SW having the same rear axle as the gti. But wouldnt think they would cause the wheel to lean in as much as it is. Another quick question. Is there an easy way to get at the fans relays without removing he front bumper? I know with the faults mounting up I would probably be better off with another car. But I've spent too much on it just to get rid of it.
2.0 SW HDi Quiksilver
Page 2 of 2
