Posted: Mon Aug 27, 2012 4:28 am |
good advise there
it would be in a garage 1 if i could afford over 100 quid in labour and 2 no one in my area does it
Posted: Mon Aug 27, 2012 1:18 pm |
there out, new ones in only took 3 days
had to hit it from one side then the other to loosen it up with some wiggling and a can of wd40
Posted: Mon Aug 27, 2012 2:04 pm |
I hope they went in with lots of copper grease on the splines...
Posted: Mon Aug 27, 2012 2:32 pm |
certainly did as i need to car tomorrow so the height was guessed. turned out about 20mm higher than what it was.not sure weather i Will lower it more as yet as i liked it as it was.
think the height its at now is best for handling.
they made a nice improvement in feel from the back and make the car feel more solid
Posted: Wed Aug 29, 2012 4:29 pm |
lots of good advice here guys! ill try some of it sometime when i get my car back from the garage!
Posted: Wed Aug 29, 2012 4:33 pm |
usher wrote: |
they made a nice improvement in feel from the back and make the car feel more solid |
i presume you fit the 22mm torsion bar?
that could be why it is higher than you would have though
Posted: Thu Aug 30, 2012 1:51 am |
yeah the 22mm ones i put in. i knew the back would raise a little with the new bars but think its also one spline higher.
look on my project just put up before and after pics
