Online Now [451]:
Visitors: 450
Today: 118760
Total: 154808731
Forums › The Car › 206 Problems › 180 with brembo's problem!!
usher
PostPosted: Thu Aug 30, 2012 12:45 pm Up
he said to me many times its not needed and now i have changed my hoses i agree with him.
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Chris180
PostPosted: Thu Aug 30, 2012 2:11 pm Up
Yes all 4 nipples have been bled on the brembos, and yeah I have braided hoses on the front only
2003 aegan blue gti 180 - CatCams 804's camshafts - CatCams vernier pulley - R.S.Tuning remap
Gti 180 Project Thread
jackspaniels
PostPosted: Thu Aug 30, 2012 2:59 pm Up
I used a 23mm master cylinder. Pedal
Travel
Was much less after. But maybe a bit less feel through the pedal.
I found a list of possible donor cars through google. Its a big list.
PEUGEOT 206 V6 FOR SALE !!!!
as seen on YOUTUBE
TEXT ME ON :07528810462
PostPosted: Thu Aug 30, 2012 3:02 pm Up
ideally you got to replace all hose in 1 go....
otherwise you are putting more stress on the old hose.
Chris180
PostPosted: Thu Aug 30, 2012 4:10 pm Up
Ok so the 23mm master cylinder is that from a 406...and will that fit with my current servo
usher
PostPosted: Thu Aug 30, 2012 5:16 pm Up
no you need the gti6 servo but its not needed even if its a track car, also you need to mess with the reservior for clutch,
project thread WIP
garage
FAQ
206 gti firedance
Chris180
PostPosted: Fri Aug 31, 2012 12:32 am Up
Ok I''ll try braided hoses on the back and see f that makes a difference
Chris180
PostPosted: Fri Aug 31, 2012 12:55 am Up
Schumi
PostPosted: Fri Aug 31, 2012 3:55 pm Up
You need non ABS Peugeot Partner M59 23.8 MC for gti 180. They have 4 output. You need 3 one.
2005 206 RC RED
Chris180
PostPosted: Fri Aug 31, 2012 4:55 pm Up
What??? Why non abs...and what is the m59 bit...and why a 3 instead of 4 output,
Steve180
PostPosted: Sat Sep 01, 2012 3:22 am Up
The M59 is the model type of Partner.
As for the output, last time I checked the GTi 180 has four output MC not 3? 2 on top, 2 on the side, 4? Or at least it was when I went to school?
2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs
jackspaniels
PostPosted: Sat Sep 01, 2012 10:13 am Up
You can find a master cylinder that has the right number of ports, the right thread for the pipe unions, fits your servo, and can fit your reservoir.
Just like i did. I went into my local breakers, looked through the tray of cylinders for Peugeot Citroen (and Renault). I found 2 or 3 that would work, picked the best one and fitted it.
as seen on YOUTUBE
usher
PostPosted: Sat Sep 01, 2012 11:42 am Up
could you expand on which one you used etc
project thread WIP
garage
FAQ
206 gti firedance
Chris180
PostPosted: Sat Sep 01, 2012 1:48 pm Up
Who...me...I used a standard git 180 master cylinder
Chris180
PostPosted: Sat Sep 01, 2012 1:50 pm Up
Page 3 of 4
