Latest: elelectricistadeMateo
Overall: 17127
Online Now [59]:
Visitors: 58
Today: 3737
Total: 100401969
Go to page Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
briant
PostPosted: Sun Sep 02, 2012 5:01 pm Up
Schumi wrote:
Nice progress Brain. But your inlet ports looking small to me. Which inlet system you will use.
I think you need GTI180 inlet manifold gasket for measurement and port match.
im using jenvey tb's & inlet manifold supplied with kit from Mtech i ported the inlet manifold as much as i could and matched the ports in the head.
my engine has rubber seals on inlet manifold so were no good for measurments
have you any pics or measurments from 180 inlet manifold ill go bigger if i can Very Happy
i need all the feedback/info i can get cant afford to send out or purchase a cyl head already ported so hoping to do work myself
206 Rallycar
Schumi
PostPosted: Mon Sep 03, 2012 3:23 am Up
Actually I have better photos of ports but I cant find now. If I remember when I go home tonight i will send much more photos.
And you will be suprise how exhaust ports bigger on gti 180. I will send exhaust ports photos to.
2005 206 RC RED
DeadEyePaul
PostPosted: Mon Sep 03, 2012 4:30 am Up
This is looking good! And I'm loving the colour choice! Good job so far!
PostPosted: Mon Sep 03, 2012 6:22 am Up
I wouldn't use the gasket to match the ports until you are 100% certain it matches the inlet.
PostPosted: Mon Sep 03, 2012 6:23 am Up
could port the inlet at the same time?
PostPosted: Mon Sep 03, 2012 6:31 am Up
I'd use a cardboard template to see how the ports compare to each other.
Schumi
PostPosted: Mon Sep 03, 2012 2:14 pm Up
On GTI180 inlet manifold gasket match to inlet manifold and same on exhaust manifold. I'm %100 sure. Smile
And exhaust manifold.
And this is after port matching photo.
img69.imageshack.us/im...mg6739.png
1 week later I will be give another little trick. But I need to be sure. Smile
2005 206 RC RED
PostPosted: Mon Sep 03, 2012 2:29 pm Up
These are the Longman inlets...how do they compare to yours?
jackspaniels
PostPosted: Mon Sep 03, 2012 3:06 pm Up
Fairplay Richard longman gives good head!
PEUGEOT 206 V6 FOR SALE !!!!
as seen on YOUTUBE
TEXT ME ON :07528810462
briant
PostPosted: Mon Sep 03, 2012 5:47 pm Up
some great pics & info thanks to all
I ported up the inlet manifold bolted it on & was able to mark cyl head through the manifold to get exact match ill compare pics to the longman head to see how it looks,
@Schumi i havent opened the exhausts as much as my exhaust manifold isnt as big as gasket so i matched cylinder head to ex manifold with made up gasket/cardboard
now im thinking my manifold(raceland stainless) is not good enuf if i can open ports more id need to get a better quality manifold to make full use of bigger ports
206 Rallycar
PostPosted: Tue Sep 04, 2012 2:18 am Up
Although I didn’t port mine myself I got some cardboard and placed it on the face of the head. Then mark out where the ports are – then cut the holes in the cardboard. Then place this on the inlet manifold to show you the size of the ports.
Schumi
PostPosted: Tue Sep 04, 2012 6:33 am Up
I didnt send final stage of ports. Today I hope i will found photos on my external drives. Smile
2005 206 RC RED
briant
PostPosted: Thu Sep 06, 2012 6:58 pm Up
engine build is now on hold issue with my steel con rods Sad
Stupid mistake by me and took too long to get build underway
www.206info.co.uk/Foru...49417.html
206 Rallycar
briant
PostPosted: Mon Oct 15, 2012 5:44 pm Up
Engine built back on track Laughing
206 Rallycar
spike_202
PostPosted: Mon Oct 15, 2012 7:46 pm Up
Forge bits look so sexy it's a shame you can't see them lol. Good progress lovin the work.
**spike's project**
TEAM:+200bhp
Page 8 of 11
