Latest: ArtistKS
Overall: 17145
Online Now [141]:
Visitors: 141
Today: 17519
Total: 115917362
Forums › The Car › 206 Talk › Should I change the drive shaft?
ssjgoku101
PostPosted: Tue Sep 04, 2012 4:22 pm Up
I noticed the other day that my 1.6 16v XSI has a split boot lid on the nearside. In addition an abs warning light's recently come on. I believe that the nearside ABS ring is probably the cause.
Do you guys recon its better/cheaper to change the boot lid and ABS ring or just opt for a new drive shaft?
Baz
PostPosted: Tue Sep 04, 2012 4:28 pm Up
the shaft rarely got damaged.
the worse case you could replace the CV joint. In fact it is getting hard to order new driveshaft.
ssjgoku101
PostPosted: Tue Sep 04, 2012 4:40 pm Up
Well I was thinking if I have to take the drive shaft off to change the ABS ring anyway it might be better to just change the shaft. J&R are selling a new one for £35 delivered. Do you recon that's easier?
Baz
PostPosted: Tue Sep 04, 2012 4:49 pm Up
LMAO, those shaft are useless!
that price is barely higher than scrap price for a used OEM shaft!
ssjgoku101
PostPosted: Tue Sep 04, 2012 5:01 pm Up
Hmmm yeah I was dubious too at first, but then again it does come with a 2 year warranty.
It's this one:
www.ebay.co.uk/itm/PEU...843wt_1296
Its £50 on ebay but £35 on their website for some reason...
Baz
PostPosted: Tue Sep 04, 2012 5:06 pm Up
It's this one:
2yr is nothing on driveshaft. my oem shaft was12 year old without a single click!
there is a reason why driveshaft aren't cheap.
and most likely they can offer cheap shaft is because they don't even proper rebuild it. most likely they buy loads of used shaft and then cleaning+new boot->resold.
ssjgoku101
PostPosted: Tue Sep 04, 2012 5:22 pm Up
Ok fair enough, ill just change the boot lid and ABS ring. Anyone got a how to on removing the nearside drive shaft (to change the ABS ring)?
Baz
PostPosted: Tue Sep 04, 2012 5:27 pm Up
www.206info.co.uk/Foru...shaft.html
ssjgoku101
PostPosted: Tue Sep 04, 2012 5:42 pm Up
Thanks Seabook, though reading through that guide makes it sound like a bloody hard job lol
Baz
Rob2859
PostPosted: Wed Sep 05, 2012 7:26 am Up
I find the shaft comes out too easily when you don't want it to...
ssjgoku101
PostPosted: Wed Sep 05, 2012 4:29 pm Up
Didn't need to take the shaft out in the end. Just cleaned out the CV area, put new grease in and installed a strong boot clip. Whoever owned the car before me used a plastic clip to hold the boot lid on lol
Baz
PostPosted: Thu Sep 06, 2012 6:09 am Up
cable tie is fine.
although metal cable tie is the one which normally used.
glad you get that sort
