Online Now [577]:
Visitors: 576
Today: 110551
Total: 154669843
Forums › The Car › 206 Talk › Need slight help with wiring Morette lights
Forum Index › 206 Talk
Go to page Previous  1, 2
mehoolkmusic
PostPosted: Wed Sep 05, 2012 2:44 pm Up
Yeah the bulb is fine as I've switched them over from the crystals I was using
Left French. Drive a Astra coupé 2004
www.soundcloud.com/mehoolkmusic
PostPosted: Wed Sep 05, 2012 2:45 pm Up
think you should trying earthing it better if its just slotted under, attach a bit of cable to yellow wire and hold other end on bare metal on the car see if works then.
mehoolkmusic
PostPosted: Wed Sep 05, 2012 2:46 pm Up
Ok will try tommorow also the motors on the morettes arnt working am I right in thinking I can swap the crystal ones over?
PostPosted: Wed Sep 05, 2012 2:48 pm Up
worse comes to it i can have a look at the wiring for a few beer tokens Wink if you get stuck
yes motors should swap over.
mehoolkmusic
PostPosted: Wed Sep 05, 2012 2:49 pm Up
Sure thing! I'll inbox you my number Wink
Page 2 of 2
