Online Now [684]:
Visitors: 683
Today: 24862
Total: 154236208
Forums › The Car › 206 Problems › Rear window rattle
Rear window rattle
lmilligan
PostPosted: Thu Sep 06, 2012 8:13 am Up
Afternoon Smile
Im starting to get a sort of rattle noise from the rear windows (3dr) sounds like they are wobbling around slighty when I go over a little bump and is obviously worse on bigger ones, but there is no noise when they are open. Anyone had this problem before and if so is there a solution because its driving me mad! I did search but nothing come up Smile
iainlovatt
PostPosted: Thu Sep 06, 2012 8:16 am Up
one window screw must be loose, go and give each hinge a pull, see what happens! Smile
(My Garage)
lmilligan
PostPosted: Thu Sep 06, 2012 8:17 am Up
I'll have a look soon Iain Smile do the plastic caps on screws just pop off on the outside?
iainlovatt
PostPosted: Thu Sep 06, 2012 8:26 am Up
Yep, The screw heads are on the inside of the car! they screw into the blocks on the outside of the window,, they may need tightening up! Smile
(My Garage)
PostPosted: Thu Sep 06, 2012 8:33 am Up
The 'cups' don't 'pop' off. Undo the screws from inside the car to remove window. The 'caps' can be pushed out then.
lmilligan
PostPosted: Thu Sep 06, 2012 10:38 am Up
Ohhh I didn't realize the screws were on the inside DOH!!! cheers Smile
lmilligan
PostPosted: Fri Sep 07, 2012 7:56 am Up
tightened up the screws on the windows and noise is still there starting to think it isnt the window
