Online Now [392]:
Visitors: 390
Bots: 2
Today: 78200
Total: 156956366
Forums › The Car › 206 Problems › 180 tapping noise continues...
PugGti180
PostPosted: Sat Sep 08, 2012 12:32 pm Up
Ok so I've changed cams, lifters, oil change and flush but still nothing changes Sad anyone got any ideas? Its driving me crazy and every garage up here says that they ain't willing to delve into taking apart an engine?! I've had mechanic mates look at it and they all say its defo the lifters but they were changed and still the identical noise. Could it be anything else? What's this fuel rail tapping I keep reading about? Could it be this? Arrgh!! Sad
2005 Peugeot 206 Gti 180, Silver, 38,000mls Wink
JamieM
PostPosted: Sat Sep 08, 2012 12:35 pm Up
Had the belts done?
Timing could be out?
Aegean Blue 206 GTi180
PugGti180
PostPosted: Sat Sep 08, 2012 12:40 pm Up
yup. New belt. Its a replacement engine and had new belt put on when I put it in. Been running fine for 2 months and outta the blue the tapping starts. Sad
JamieM
PostPosted: Sat Sep 08, 2012 12:51 pm Up
Had the belt checked since?
Could be loose or something.
idk other than that mate sounds a b*****d though!
PugGti180
PostPosted: Sat Sep 08, 2012 12:57 pm Up
Belt was checked today when cams and lifters were changed. What else in the he'd could make that noise? Do you know about the tapping fuel rail thing I keep reading on the net?
138Andy
PostPosted: Sat Sep 08, 2012 2:39 pm Up
Exhaust rattle ? Razz
or does it tap faster when you rev
PostPosted: Sat Sep 08, 2012 2:59 pm Up
what cam and lifters did you use?
brand new? used? oem? cheap pattern?
PugGti180
PostPosted: Sat Sep 08, 2012 3:13 pm Up
Taps faster when rev'd. They are oem cams I took outta my last engine but cams were ok. Not scored or anything.
PostPosted: Sat Sep 08, 2012 3:21 pm Up
what lifters did you use then?
old stuff?
did you mixed up with the order?
PugGti180
PostPosted: Sat Sep 08, 2012 5:36 pm Up
Lifters I had refurbed professionally. What else apart from lifters and cams could it be?
PugGti180
PostPosted: Sat Sep 08, 2012 5:38 pm Up
hold on... What order?
PostPosted: Sun Sep 09, 2012 11:05 am Up
if you got new lifers then there is no order.
however if you use 2nd hand lifers your suppose to use the corresponding camshaft as well and not to swap the order of the lifters. (as lifers and camshaft lends to wear out differently at different position)
what oil did you use?
Schumi
PostPosted: Mon Sep 10, 2012 3:52 am Up
Did you change your oil pump ?
2005 206 RC RED
Rich363
PostPosted: Mon Sep 10, 2012 7:11 am Up
Sticky Valve perhaps??
PugGti180
PostPosted: Mon Sep 10, 2012 1:43 pm Up
Castrol magnatec. Oil pump is fine as oil is reaching the head fine. A sticky valve? Tell me more..
