Online Now [243]:
Visitors: 242
Today: 31762
Total: 155750439
Forums › The Car › 206 Talk › 206 axle fit?
206 axle fit?
Forum Index › 206 Talk
BigGreenDave
PostPosted: Thu Sep 13, 2012 5:36 am Up
206 1.4 2000 chasi
206 GTi 180 2004 axle
Will it fit?
F**k Scene YAWN
PostPosted: Thu Sep 13, 2012 8:28 am Up
No
PostPosted: Thu Sep 13, 2012 9:16 am Up
Need to mess around getting the correct ABS sensors fitted, may have to change other components as well but it is possible
If you want the lateral bars you also need a new backbox / middle pipe best to get one custom made (if you want to remove them may as well just get the 180 torsion bars and ARB)
Andrew
PostPosted: Thu Sep 13, 2012 9:22 am Up
Is it just a case of rerouting the exhaust pipework with the 180 axle? ie, cut the exhaust, pipe bend, weld in aditional bends etc. Are the multiplex ABS sensors on the 180 the same as all multiplex ABS models? Sorry to threadjack
My 206 thread
www.detailedbyandrew.com
PostPosted: Thu Sep 13, 2012 10:01 am Up
It is, sure an exhaust place could cut and modify but your existing back box may get in the way, it's hard to tell without trying or at least trying to measure
Yes they are exactly the same, plug and play if yours is already plexxed
Andrew
PostPosted: Thu Sep 13, 2012 10:02 am Up
Not an issue for myself, cheers for the advice
My 206 thread
