Online Now [1119]:
Visitors: 1118
Today: 302261
Total: 151422226
Forums › The Car › 206 Problems › car has a mind of it's own!
alfie
PostPosted: Thu Sep 13, 2012 2:43 pm Up
Hi all,
I'm new to this site and i'm looking for a solution to the problem i have with my wifes 2000 1.4 206,
When i start the car from cold ( sometimes not every time) the revs increase by themselvs and if you try to pull away the engine coughs and dies. once warm it does'not do it so often, sometimes not at all and the engine ticks over and runs realy smoothly.
Any ideas as this is now starting to get on my nerves!
Cheers
Alfie
bugawuga
PostPosted: Thu Sep 13, 2012 3:00 pm Up
Try a battery test to determine if the battery is holding its charge properly.
If the battery is healthy it may be worth checking the condition of the air filter and spark plugs.
If they look good consider the idle control valve.
Davies
PostPosted: Thu Sep 13, 2012 3:39 pm Up
More than likely the Idle Control Valve, common problem!
Poppy, My 2.0 HDI Dream Wink
sybiriya
PostPosted: Mon Sep 17, 2012 8:39 am Up
excuse my lack of car knowledge but im just wondering is the idle control valve similar or the same as a egr valve as on my old car we had this exact problem and tried everything till we put it into a dedicated place who told us it was the egr, which we had already tried but because the cars computer wasnt reset so the car didn't register it as a different one, crazy eh. just thought i share that to see if it helps tho =)
=D
finbowgti180
PostPosted: Mon Sep 17, 2012 3:44 pm Up
try the search bar in the top right corner "idle control valve" came up with alot of things
Blue 206 gti 180 - standard................for now Wink
Bigbenj_08
PostPosted: Mon Sep 17, 2012 3:49 pm Up
Had a similar issue on mine which turned out to be either the throttle body sticking or a dirty map/maf sensor.
Followed this guide and all fixed..
www.206info.co.uk/Foru...tml#527235
Aegean Blue 1.6 16v Sport
MrrNoName
PostPosted: Tue Sep 18, 2012 3:09 am Up
It could well be the ICV.
See here for the Idle Control Valve and how to clean it (bare in mind that they differ depending on your engine though!)
my206xr.blogspot.co.uk...l/Throttle
