Latest: tc.206
Overall: 17147
Online Now [278]:
Visitors: 278
Today: 13383
Total: 116555848
Forums › The Car › 206 Problems › mot fail high CO/lambda reading
gazb85
PostPosted: Sat Sep 15, 2012 12:18 pm Up
hi all
I've got a 2000 206 1.4 petrol and when it went for its mot it failed on the CO and lambda reading. The CO was 1.119 and the lambda 1.099. Can anybody shed any light on possible reasons for this?? Would a change of oil/oil filter and cleaning of the throttle body help bring these down?? According to the guy at the test centre my car is "running rich" and the exhaust seems like the exhaust has a large amount of pressure.
I've seen all the threads on here that say to fill it with redex and take it for a good drive but still failed.
Any help would be appreciated.
PostPosted: Sat Sep 15, 2012 12:46 pm Up
sort out the lambda first; most likely it will clam down the CO as well.
no harm to make sure the air filter is clean as well.
redex is just snake oil
gazb85
PostPosted: Sat Sep 15, 2012 12:58 pm Up
the car had a cone air filter when i bought it and i swapped that just before its retest with a proper 206 filter box and filter and it still failed :-/
gazb85
gazb85
PostPosted: Sat Sep 15, 2012 1:10 pm Up
PostPosted: Sat Sep 15, 2012 1:31 pm Up
well like i said you need to check if the lambda is giving out the correct value.
if the sensor is fine then high lambda usually means air leak around the sensor.
boosted
PostPosted: Sat Sep 15, 2012 3:23 pm Up
i had the same problem in my old 206 1.4, got a new lambda sensor and it went straight through the re test
