Posted: Sun Sep 16, 2012 12:47 pm |
Tbh i would get a cheap code reader of ebay - £30 or so, one with 02 sensor parameters is always handy
But i sort of need to know whether the code was for a misfire OR an injector fault. As a misfire on 3 (second from cambelt) could indicate a coil or spark plug.
One way of seeing if the fault is with 3 or 4 is to remove the HT Lead/Lug which sits over the spark and for example you remove number three and it runs the same then its 3.
Try it with 4 too though, if the running gets worse with which ever one remove than you know that cylinder is fine.
Only remove one at a time
Report back with your findings
| Team Impossible Possible
Posted: Sun Sep 16, 2012 1:49 pm |
Trade Rating: +16
i know its one in the middle, what i mean is, is it 3rd from the left of the car if your looking at it from the front or is it 3rd from the right?
never had to to check today addaz, will check in the week
whats the ht lead? i thing i get you, so remove the coilpack and take off one of the 4 things that are on it?
the mot station said it was for the injector, the car misfires loads when pulling off
Posted: Sun Sep 16, 2012 5:36 pm |
On Peugeot/Citroen vehicles cylinder 1 is on the right looking from the front.
Posted: Mon Sep 17, 2012 1:09 pm |
Trade Rating: +16
V9977 wrote: |
On Peugeot/Citroen vehicles cylinder 1 is on the right looking from the front. |
thanks
Posted: Mon Sep 17, 2012 1:10 pm |
Trade Rating: +16
found my problem
put the injectors on a multimeter to read the independence
injector 1 15.2
injector 2 15.2
injector 4 15.1
injector 3 0
thanks for all the help
also the garage was wrong and wanted to charge £130 not inc vat to fix injector 4!!!!
