Latest: flipflap
Overall: 17140
Online Now [543]:
Visitors: 542
Today: 60380
Total: 113860387
Forums › The Car › 206 Problems › Rear lights intresting problem!
frenchfrog40
PostPosted: Mon Sep 17, 2012 6:21 pm Up
I recently put the 206 sport lights that came on my old 180 onto my new xsi as the original lights were flooding. Then a few weeks later I changed the left break light as it had blown.
Tonight I noticed (so its only started since changing bulb) that the indicators and break lights are fine. However, when you lock or unlock the car or put hazards on something odd happens.
The left cluster doesn't do anything, the right break light flashes (just like indicators do in hazards) and so does the 3rd break light.
Any ideas what's going on?
Thanks.
Iv had:
MrZiggerz
PostPosted: Mon Sep 17, 2012 7:07 pm Up
Try to clean the connections as good as possible.
MrrNoName
PostPosted: Tue Sep 18, 2012 3:13 am Up
It could be a 'Dirty Earth'.
As said, check all of the connections to see if any are damaged. When the earth connection is bad the lights can earth through eachother causing strange effects!
frenchfrog40
PostPosted: Tue Sep 18, 2012 3:43 am Up
ok, ill have a look at these when i get a chance, thanks.
im planing on getting some black rear lights asap, shall i just wait untill i put these in?
Iv had:
frenchfrog40
PostPosted: Tue Oct 09, 2012 4:53 am Up
fixed them the other week, took the side carpet off in the boot and the bolt that holds the earth cables on was hanging down and both earth cables were waving around. easy fix in the end Smile
Iv had:
