Online Now [525]:
Visitors: 524
Today: 101558
Total: 155581547
Forums › The Car › 206 Problems › Seat won't lock in
Seat won't lock in
karimali831
PostPosted: Tue Sep 18, 2012 7:24 pm Up
The drivers seat is in the laying position and the handles won't go back to change position? Handled only go forward, any ideas broken seat :s ?
Gti 180 standard drivers seat
Thanks!
206 GTI 180
uttz
PostPosted: Tue Sep 18, 2012 9:00 pm Up
make sure its level.. as in the right side and laft side are square..sometimes just need little wiggle but u should hear the click once its in
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
karimali831
PostPosted: Wed Sep 19, 2012 3:30 am Up
I've tried that, it just wont tilt backwards, finally getting the bsi updated.. Maybe they can get fixed for me.
206 GTI 180
iainlovatt
PostPosted: Wed Sep 19, 2012 3:50 am Up
i have the same issue with a 180 seat in the shed. Think the frame is gone, i would retrim onto another frame, Smile
(My Garage)
PostPosted: Wed Sep 19, 2012 3:53 am Up
I had the same problem with my old seats, it's a bar underneath which jammed, take the seat out and have a play, it may be the same thing, If so check to make sure the bar is not jammed which is literally under the seat cover flap, should move up and down if not
karimali831
PostPosted: Wed Sep 19, 2012 3:56 am Up
So it took me 3 hours to fit an sp grill and have a 5 minute layin just to find out it no longer locks upright, bad design? I'm just 11 stones.
206 GTI 180
karimali831
PostPosted: Wed Sep 19, 2012 3:59 am Up
I looked there nothing jammed in the centre, must be where the handles are. Possibly have to remove the trims.
206 GTI 180
JamieM
PostPosted: Wed Sep 19, 2012 8:29 am Up
I have the other issue,
Thankfully not driver side!
My pas side can't be adjusted luckily it's set up to a comfortable arrangement!
Aegean Blue 206 GTi180
karimali831
PostPosted: Wed Sep 19, 2012 12:09 pm Up
I couldn't sort it but had it sorted at Peugeot dealer, they just had to re-align something.. Cool
206 GTI 180
