Posted: Wed Sep 19, 2012 12:06 pm |
noticed this this morning only happens when car is cold..just sounds as if it doesnt want to start then when it does start all the dash lights dim down and a consent bleep starts anyone no wats wrong?
s943.photobucket.com/a...76b91a.mp4
Posted: Wed Sep 19, 2012 12:13 pm |
it tells you whats wrong does it not? anti pollution fault? try getting the codes read....
Posted: Wed Sep 19, 2012 12:25 pm |
the anti pollution fault has been up for a while and this has came on all of a sudden
Posted: Wed Sep 19, 2012 1:22 pm |
Battery
Posted: Wed Sep 19, 2012 1:31 pm |
I'm saying battery as well!
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Wed Sep 19, 2012 2:00 pm |
Check the fault codes first, get the battery tested or just check it with a good donor one to see if the fault goes
But from what i saw on the video doesnt look like a battery but from what you describe it does sound similar (if you didnt have the anti polution fault i would firstly suggest battery, but since you do....)
| Team Impossible Possible
Posted: Wed Sep 19, 2012 2:10 pm |
if it gives you a "Bongggg" sound,then that means your battery is weak,and need to be replaced ASAP,you will have more problems caused if the low voltage when you start your car.
Posted: Wed Sep 19, 2012 2:19 pm |
Mine did this. Battery.
| - Sinature removed due to size.
Please feel free to upload one of the correct dimensions. | |
Posted: Wed Sep 19, 2012 4:14 pm |
I had that problem when my last car was mapped, turned out to be the maf sensor, it was either cleaned or replaced and all was well.
Posted: Wed Sep 19, 2012 5:15 pm |
Another vote for battery.
Posted: Thu Sep 20, 2012 1:43 am |
yep battery!! i lived with the beep for a month or so till one day it didnt start!
When you get a new battery go for a decent one, not a cheap one as it wont last!
Posted: Thu Sep 20, 2012 2:05 am |
| JamieM wrote: |
| I had that problem when my last car was mapped, turned out to be the maf sensor, it was either cleaned or replaced and all was well. |
There is no MAF in Peugeot. Your problem could be MAP.
My bets on battery.
| 2005 206 RC RED
Lot's of CNC machined customs pars.  | |
Posted: Thu Sep 20, 2012 6:28 am |
| nellyhaggis wrote: |
| Mine did this. Battery. |
Yes you need a new battery,buy a new 55 mAH,a decent one ,like VARTA,or Delfie,or Fiamm
Posted: Thu Sep 20, 2012 6:38 am |
| Schumi wrote: |
| JamieM wrote: |
My bets on battery. |
Going by what I was told maybe it was o2 sensor it was like 7 years ago. It's not my current car.
It was definitely a sensor though and after it was cleaned it ran sweet.
Either way,
Battery causing the cut yeah and beeps yeah
Battery causing the anti pollution fault?
Posted: Thu Sep 20, 2012 6:52 am |
| JamieM wrote: |
| Schumi wrote: |
| JamieM wrote: |
Either way,
Battery causing the anti pollution fault? |
It's french electrics, mysterious things that have no link between the two can happen.
