Latest: S2cgm
Overall: 17178
Online Now [108]:
Visitors: 107
Today: 27608
Total: 136883712
Forums › The Car › 206 Problems › Drivers Door Leak
Drivers Door Leak
mattvaretto
PostPosted: Fri Sep 21, 2012 2:24 am Up
So I noticed this morning I have a very small leak from my drivers side front door (5 door model). It's coming from the top right in the middle and dripping down the door card and sometimes onto my seat. I had a quick look at the rubber seal and couldn't see any problems but it was wet.
Anyone any ideas?
Cheers
PostPosted: Fri Sep 21, 2012 6:11 am Up
check the drain hole on the door
mattvaretto
PostPosted: Fri Sep 21, 2012 7:12 am Up
Where abouts is that?
mattvaretto
PostPosted: Fri Sep 21, 2012 7:20 am Up
Nevermind had a quick search and found out Smile
PostPosted: Fri Sep 21, 2012 8:57 am Up
If it's coming from the top of the door then it's most likely the seal that's worn. Check the frame above the window to make sure someone hasn't tried to bend it to get a coat hanger in.
The obvious one, have you checked to make sure the window is closed properly?
mattvaretto
PostPosted: Fri Sep 21, 2012 10:19 am Up
It's only a very small drip. Had a look before and there's no damage to the door the window was definitely up was the first thing I checked and had a look at the seal but it looked ok. No obvious signs of wear gonna keep my eye on it this week and pour some water over and see if any more gets in
