Online Now [224]:
Visitors: 222
Bots: 2
Today: 61717
Total: 155852835
Forums › The Car › 206 Problems › Clock/display very dim
ed2k12
PostPosted: Fri Sep 21, 2012 11:36 am Up
My clock/central display on my newly aquired 2002 206 is really dim.
I think it is the 3 backlight bulbs that need replacing.
Does anyone know the exact type of bulb I can google to buy and even give me a URL.
The problem i have found is that the contacts are not directly above one another and slightly off set making some bulbs I have already bought obsolete Confused
HELP!!!
jk206
PostPosted: Fri Sep 21, 2012 12:09 pm Up
there is 2 buttons on the instrument cluster, the one on the left is to dim the interior lighting and the one on the right is to rest the mileometer.
or on different models the dimer is a wheel next to the air bag light so id try that before buying bulbs
jk206
PostPosted: Fri Sep 21, 2012 12:10 pm Up
air bag on/off switch i mean
ed2k12
PostPosted: Fri Sep 21, 2012 1:08 pm Up
yep, have tried this but doesn't solve the problem.
just finding it hard to find the exact bulbs to buy
PostPosted: Fri Sep 21, 2012 1:14 pm Up
Just go to a Peugeot / Citroen main dealer & buy them, there cheap enough.
Matt
PostPosted: Fri Sep 21, 2012 3:10 pm Up
Trade Rating: +32
HELP!!!
You need a new battery. Old one isn't powerful enough.
PostPosted: Fri Sep 21, 2012 3:14 pm Up
HELP!!!
? It will start the car, but not power 3 12v bulbs? Bulbs have blown, Halfords will sell them.
Might be these
www.ebay.co.uk/itm/10-...3f09094028
Matt
PostPosted: Fri Sep 21, 2012 3:59 pm Up
Trade Rating: +32
HELP!!!
Might be these
Might be alternator as well then.
ed2k12
PostPosted: Fri Sep 21, 2012 8:07 pm Up
HELP!!!
Might be these
Dont know if it is these, I can't tell form the ebay pic but what makes the bulbs awkward to buy is the fact that the metal contacts are not directly above each other like the ebay pictures make it look like.
madigg
PostPosted: Fri Sep 21, 2012 8:34 pm Up
I just replaced clock and dashboard backlight LED's. I bought a set that didn't fit before finding these: www.ebay.co.uk/itm/280..._500wt_923
You need to bend the top metal part down slightly so they fit in tightly.
Edit: Same as the ones posted previously! The metal contacts don't need to be directly above each other. The difference between the "wrong" type is that the metal connectors are too far apart to be a tight fit, or that they are too long so wont fit in. The ones linked have a bend in the metal contacts so they can be twisted into place.
Example of the wrong type to buy: www.ebay.co.uk/itm/180...727wt_1397
ed2k12
PostPosted: Fri Sep 21, 2012 8:56 pm Up
Thanks for the info, is it the clock with the 3 backlights?
Did you bend the top contact downward to the other contact only? or sideward as well to match the original bulb?
madigg
PostPosted: Fri Sep 21, 2012 9:03 pm Up
My clock has a single LED (orange display above hazard button). The bulb fits in anything behind the dash (2001 206 1.1L lx - doubt it matters though) - I bent the top contacts down only - slightly, maybe 1 mm at the most. Twisted the old ones out, twisted the new ones in. They are not as perfect as the originals but they are very close. If you bend the contacts down enough they wont rattle and are very sturdy. I noticed also with some other LED's you get a different whiteness to the light and some dash indicators end up weird coloured, like the handbreak indicator being pink instead of red. These ones have basically identical whiteness to the originals.
To be 100% sure it is the LED's just check the voltage across the contacts with a multimeter. Should read around 12v. My dash wouldn't light up and there was no voltage - went straight to the fusebox and saw F22 fuse was missing!
madigg
PostPosted: Fri Sep 21, 2012 9:15 pm Up
My clock is something like this:
I assume yours is like:
I can't be 100% sure but I think the LED's will be the same. Worth a shot for the price anyway.
