Latest: Flyin180
Overall: 17116
Online Now [28]:
Visitors: 27
Today: 457
Total: 95031039
Forums › The Car › 206 Problems › cant replace radio connections cut
elw91
PostPosted: Sun Sep 23, 2012 12:51 pm Up
Hi i got my 206 yesterday and tried changing the radio, as i took the radio out i realised that the iso blocks have been cut off so i cant connect and looks like it was hard wired into another stereo but i cant find out what each wire is, what can i do please help!!!
elw91
its a 99 t reg 3 door
parkesie
PostPosted: Sun Sep 23, 2012 1:21 pm Up
Chop connections out of a scrapper wire up plug in.
Signature p**s
broadblaster
PostPosted: Sun Sep 23, 2012 1:25 pm Up
as above go to scrap yard and cut out the connectors with enough wire to reconect them into your car.
on a back road playing
Lewis
PostPosted: Sun Sep 23, 2012 1:39 pm Up
Why would someone do this. Just get the adaptors, tight gits. Hope you sort it mate
Tivoli LX 1.1
Black GTI 180
White VXR Burg
PostPosted: Sun Sep 23, 2012 2:06 pm Up
I can get you the part of the loom you need for a couple of quid
elw91
PostPosted: Sun Sep 23, 2012 2:22 pm Up
thanks for the replies, ill go to scrap yard tomorrow and see if i find it, thanks lee ill see what i find tomorrow and ill get back to you
Danielpates
PostPosted: Sun Sep 23, 2012 4:04 pm Up
To test speakers use an aa battery ans see which one crackles that's how Ive done it before when had this problem and I take it you know what the red yellow and black wires do
elw91
PostPosted: Mon Sep 24, 2012 3:11 am Up
We'll I don't have a black or red wire. I've got one plug in tact which I guess is the steering controls. I've then got 4 wires which I think are speaker cables and then I've got 5 wires that are taped together but only three come out and they are green and yellow the other is white and other is blue. The two cables that aren't after the tape is a thin white one and a thin grey one
elw91
PostPosted: Mon Sep 24, 2012 3:12 am Up
I also don't have a yellow wire
elw91
PostPosted: Tue Sep 25, 2012 11:00 am Up
the radio is now fitted but not without problems, the cd player would only power up with the red and yellow wires touching, so i decided to check the wires and nothing was registering with one (blue one) so i deciding to cut into the power cable for the clock, and the cd player works perfect and keeps its memory. now the problem i have is that it seems to be taking to much power from the clock so the clock is not lighting up but it is still working as you can just about see it when you shine a touch onto it, i read on here that you can use the cigarette lighter cable as the memory cable, but how do you get the cigarette lighter out or is there anywhere else i can put this cable to keep the memory on cd player, thanks
