Latest: Andyblue64
Overall: 17123
Online Now [217]:
Visitors: 216
Today: 14717
Total: 98101974
Forums › The Car › 206 Problems › Clutch release problem
Martin_HDi
PostPosted: Thu Sep 27, 2012 10:05 am Up
Hi, had a new clutch kit installed and got told the clutch is not releasing, with the pedal fully pressed still a slight bite.
Already had a clutch cylinder replaced, are there 2 in the car?
Clutch is complete kit from sachs and flywheel should also have been inspected.
Any help on how to fix this would be greatly appreciated!!
clutch
206 HDi
PostPosted: Thu Sep 27, 2012 2:03 pm Up
Is it fully bled? Ie the slave cylinder, and no you just have the slave cylinder located on the side of the box
Was the release arm damaged in any way? Pressure plate fitted correct way round?
weeman
PostPosted: Fri Sep 28, 2012 3:37 pm Up
as above, sometimes if the slave cylinder isnt clamped off when its disconnected from gearbox the piston can pop past the seal. not always doing permenant damage but would deffo need re bleeding. is there any free play/ adjustment on the pedal/push rod itself? ie getting full pedal travel. may not a clutch master cylinder issue if it was fine before the clutch being fitted...
Martin_HDi
PostPosted: Sat Sep 29, 2012 2:29 pm Up
Thanks for the help!
The cylinder was replaced and they bled it too. I'll check on monday for full travel in the pedal and the release arm, although all was fine before the clutch replacement
Was also checking if the components in the kit matched up on webcat.zf.com/ but could not find anything wrong (garage are running out of ideas too)
Will post if i can find anything
206 HDi
