Online Now [699]:
Visitors: 698
Today: 126714
Total: 157432238
Forums › Tuning, Modification & Legal › Project Cars › DeadEyePaul's Savage Red *engine done!* d9
Go to page Previous  1, 2, 3 ... 11, 12, 13, 14  Next
jackspaniels
PostPosted: Thu Sep 27, 2012 2:07 pm Up
Any videos yet?
PEUGEOT 206 V6 FOR SALE !!!!
as seen on YOUTUBE
TEXT ME ON :07528810462
DeadEyePaul
PostPosted: Thu Sep 27, 2012 2:15 pm Up
It's a bit difficult to record an drive at the same time, how did you do it?
jackspaniels
PostPosted: Sun Sep 30, 2012 9:34 am Up
The top speed video was done by holding the camera and the wheel at the same time. Not easy or recommended.
For hill climb videos I used a variety of cameras and mounts, I was never very happy with the results.
The common trend on YouTube is to have someone in the passenger seat filming (with a steady hand hopefully)
as seen on YOUTUBE
Mattie-RS
PostPosted: Sun Sep 30, 2012 1:31 pm Up
Mounting it to the roll cage is the best Wink
deadrange2001
PostPosted: Mon Jan 07, 2013 2:10 am Up
The project is absolutely amazing but...
Which springs/shocks are you using in front?
Stock ARB in the front? Have been any modifications done to the front subframe?
Are your wishbones stock? Any front camber and caster modification ?
Did you balance the weight increase on the car with rear deadweight?
I think a strut brace would help a bit...
Also, how is oversteering compared to the stock one?
Is your car multiplexed or not?
Is the engine ES9J4 or J4S? Smile
Please excuse the number of questions Smile
DeadEyePaul
PostPosted: Mon Jan 07, 2013 2:39 am Up
Supply and fit Peugeot D9 series V6 engine.
Engine number is.
10fj2c
gearbox to Peugeot 206.
Supply and fit the following parts
Engine mounts
Drive shafts
Radiator
Slim line cooling fans
Hydraulic clutch conversion
Exhaust system
Engine wiring harness
Ecu
Cable throttle conversion
Gear stick/selector
PAS pump and pipework
Cda carbon air filter
Coolant header tank
I have fk automotive coil overs and gti-6 brakes
deadrange2001
PostPosted: Mon Jan 07, 2013 3:00 am Up
"gearbox to Peugeot 206" -> Whoa, you mean you kept the original BE4 gearbox ? I assume no since you have the clutch conversion and driveshafts...
D9 V6 is ES9J4 (194 BHP). Was your car MUX or Non-Mux (one or two buttons on the ignition key). MUX is horrible to modify... "Cable throttle conversion" means you had MUX...
Thanks for sharing the info, it is gold.
DeadEyePaul
PostPosted: Mon Jan 07, 2013 3:05 am Up
I had mux yes
I had problems with the gearbox set up and sent it back and got the 406 gear box now
deadrange2001
PostPosted: Mon Jan 07, 2013 4:01 am Up
And now is non-MUX? Was the engine MUXed ? Did the tuner have to "marry" the ECU to the BSI?
PostPosted: Mon Jan 14, 2013 12:45 pm Up
It is a piggy back ECU set up.
deadrange2001
PostPosted: Fri Jan 18, 2013 9:36 am Up
Thanks. So it's more complicated.
Rob206
PostPosted: Fri Jan 18, 2013 12:11 pm Up
love this car bet it flys
DeadEyePaul
PostPosted: Fri Jan 18, 2013 1:21 pm Up
It does indeed! But in this icey weather im going to take it slow elderly style
Rob206
PostPosted: Fri Jan 18, 2013 1:44 pm Up
dont blame you mate u need to get some videos up when you can and how did you do that picture off ya car for signiture
DeadEyePaul
PostPosted: Fri Jan 18, 2013 1:46 pm Up
There is a signature request thread on here on someone kindy made the banner for me after I submitted a picture of the car :8
Page 12 of 14
