Online Now [311]:
Visitors: 310
Today: 84720
Total: 156604308
Forums › The Car › 206 Problems › Faulty Engine Temp Sensor
PostPosted: Wed Oct 03, 2012 4:06 pm Up
If a engine temp sensor was no longer working would it prevent the engine from starting but let it turn over?
PostPosted: Wed Oct 03, 2012 4:14 pm Up
Nope.
But crank shaft position (CPS) for e.g. would.
PostPosted: Wed Oct 03, 2012 4:26 pm Up
he have just replace that i think...
the engine may run rough and rich but it will start for sure
PostPosted: Wed Oct 03, 2012 4:31 pm Up
His has a cam pos sensor too no?
Just so many things that could cause turn over but not start.
PostPosted: Wed Oct 03, 2012 4:43 pm Up
You checked the timing? That hasnt jumped a tooth has it?
PostPosted: Thu Oct 04, 2012 10:23 am Up
Both throttle pos sensor and crankshaft sensor have been replaced
PostPosted: Thu Oct 04, 2012 3:59 pm Up
Repeat whats again wrong with your car?
