Online Now [362]:
Visitors: 360
Members: 1
Today: 71853
Total: 156308332
Forums › The Car › 206 Talk › 180 rear axle???
180 rear axle???
Forum Index › 206 Talk
anton1989
PostPosted: Wed Oct 03, 2012 1:30 pm Up
Trade Rating: +16
do all the 180 rear axles have sway bars?
the 206 that i got from carlos was ment to have a 180 rear axle but im 90% sure its not, and his not to happy either as thats what he thought he had Shocked
here are some pics
138Andy
PostPosted: Wed Oct 03, 2012 1:37 pm Up
Peugeot Information Board wrote:
From the 138 to the 180 the trailing arm and torsion bar setup has been modified with the addition of a pair of tie rods in an effort to improve the axle's stability.
anton1989
PostPosted: Wed Oct 03, 2012 1:48 pm Up
Trade Rating: +16
thought so Sad
PostPosted: Wed Oct 03, 2012 2:36 pm Up
Which ship wreck did that rotter come from?
That axle doesnt even appear to have the mounting bosses that were part of the later trailing arms. I reckon that's an exle from 2002 ish. Appears to have the later handbrake levers on the calipers.
PostPosted: Wed Oct 03, 2012 2:53 pm Up
was thinking it looked pretty rusty lol
yeah thats def not a 180 axle
anton1989
PostPosted: Wed Oct 03, 2012 3:04 pm Up
Trade Rating: +16
yeah its been sitting for years!!!! have no idea on the backgroud on it, came on a car i bought on here.
do you reckon it could be cleaned up?, or is it passed it lol. i have drums so was hoping to swap?
PostPosted: Wed Oct 03, 2012 3:08 pm Up
It's very heavily corroded. You'll really struggle to make it perfect.
anton1989
PostPosted: Wed Oct 03, 2012 3:37 pm Up
Trade Rating: +16
do you think its worth the headace? got it for next to nothing
where would i start? how can i get rid/treat the rust? not exspecting to get it perfect
usher
PostPosted: Wed Oct 03, 2012 3:54 pm Up
wire brush really i would say unless you get it shot blasted but i would check it over before paying money to have it done,
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Wed Oct 03, 2012 4:24 pm Up
that axle looks worse than mine......
nellyhaggis
PostPosted: Wed Oct 03, 2012 5:27 pm Up
Angle grinder with wire wheel.
Dont forget a mask and some thick trousers.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PezHdi
PostPosted: Wed Oct 03, 2012 6:47 pm Up
Just wondering. Is it possible to put larger disc's and calipers on this axel and if so what off?
I no the front does more breaking than the back but i think the discs with the 180 (Challeger /vortex wheels) Look a little small.
The reason i ask is because i want to put 302mm discs on the front :]
Cheers Pez
EXL Pez
PostPosted: Wed Oct 03, 2012 6:53 pm Up
there wasn't any easy solution
Schumi
PostPosted: Thu Oct 04, 2012 3:15 am Up
Cheers Pez
Just use 207GTI or C4 VTS front brake setup with Calipers and disc. They are 302mm and required 16" wheels minimum.
2005 206 RC RED
Steve180
PostPosted: Thu Oct 04, 2012 5:59 am Up
If you want bigger rear discs you could get the 406 v6 rear 290MM discs and calipers in under the 180 wheels? Calipers 2nd hand be about £50.00 the pair, new discs shouldn't be much more than £80.00 for a REALLY decent set and pads about £30/40. As the calipers are also setup for handbrake it means no faffing with a secondary caliper or hydrualic handbrake setup Very Happy
2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs
