Online Now [386]:
Visitors: 385
Today: 139702
Total: 154946928
Forums › The Car › 206 Talk › 180 rear axle???
180 rear axle???
Forum Index › 206 Talk
Go to page Previous  1, 2
PostPosted: Thu Oct 04, 2012 6:36 am Up
i am very much doubt you can use the 406 rear disc.
Even the caliper might fit i doubt you can use their disc
Lecktorious
PostPosted: Thu Oct 04, 2012 7:05 am Up
Trade Rating: +59
Can be done, there is a guy on PSC UK running a vented set-up on a 309 beam, fitted to his 205.
'98 Nile Blue 306 GTi 6
PezHdi
PostPosted: Thu Oct 04, 2012 10:02 am Up
I'll look in to it ;] Like i said i no most of the breaking is on the front but if i have bigger front discs then i want bigger back ones else it will look stupid Razz
EXL Pez
PostPosted: Thu Oct 04, 2012 10:32 am Up
how? surely it need fair a bit of mod?
406 rear caliper different caliper PCD ; disc offset is way off, and even handbrake design are completely different (integrated drum for handbrake)
usher
PostPosted: Thu Oct 04, 2012 11:37 am Up
Steve180 wrote:
If you want bigger rear discs you could get the 406 v6 rear 290MM discs and calipers in under the 180 wheels? Calipers 2nd hand be about £50.00 the pair, new discs shouldn't be much more than £80.00 for a REALLY decent set and pads about £30/40. As the calipers are also setup for handbrake it means no faffing with a secondary caliper or hydrualic handbrake setup Very Happy
that won't work at all there is no easy option for the brakes. your best option is seat coupe brembo caliper as you can get 300mm disks easily to fit with a custom bracket made up the 406has the wrong off set
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
anton1989
PostPosted: Thu Oct 04, 2012 1:09 pm Up
Trade Rating: +16
thread jack lol
PezHdi
PostPosted: Fri Oct 05, 2012 4:37 pm Up
Sorry Bro its my fault :[
EXL Pez
anton1989
PostPosted: Fri Oct 05, 2012 4:53 pm Up
Trade Rating: +16
lol i aint bothered got my answer
Page 2 of 2
