Online Now [369]:
Visitors: 368
Today: 34497
Total: 156646789
Forums › The Car › 206 Problems › 206 ecu fault, again!!
PostPosted: Fri Oct 05, 2012 12:22 pm Up
So turns out my issue with the 206 is a ecu fault yet again, turned out it was overheating, when a ecu specialist came to look at it and plugged it into their machine it turned all the lights on it red.
Spoke to them earlier and they said it was full of water, i'm assuming it's got in through the bonnet vent, there is a slight gap between the plastic trim and the bonnet itself.
Anyone with ph1 206's heard or had this issue? I'm assuming that's why they put ecu covers on the ph2 206's.
PostPosted: Fri Oct 05, 2012 12:28 pm Up
If the ecu is still servicable & you can get it apart then a small drain hole or 2 correctly located should help in the future.
It would also help if you could stop the water getting in to it in the first place Laughing
PostPosted: Fri Oct 05, 2012 12:39 pm Up
I am trying to sell it at the mo but may buy a ecu cover from a ph2 and fit that til it's sold
PostPosted: Fri Oct 05, 2012 12:50 pm Up
The ECU innards are encapsulated in rubber stuff making them water-tight.
This means the board and connectors are efectively stuck onto the ECU casing.
I would open it up (four torx screws underneath) to see what is going-on in there.
See if there is rust shorting the connector metal lines to the rubberized 'block' and just how wet it is in there.
PostPosted: Fri Oct 05, 2012 1:53 pm Up
You got a leaking water temp sensor or washer pump by any chance?
PostPosted: Fri Oct 05, 2012 1:55 pm Up
Addaz wrote:
You got a leaking water tempt sensor
Shhhhhhhhhh dont give away all the Peugeot / Citroen secrets Laughing
PostPosted: Fri Oct 05, 2012 2:11 pm Up
As in how bad they literally can be? Laughing
