Online Now [277]:
Visitors: 276
Today: 112564
Total: 155069401
Forums › The Car › 206 Problems › ABS/ESR Fault
ABS/ESR Fault
dafatkid88
PostPosted: Sun Oct 07, 2012 3:59 pm Up
Hiya guys, am new to this forum but was hoping you may be able to help me..
I have a 206 GTi180 and at the weekend tried fitting a set of lowering springs much to a massive FAIL lol
but anyways we wasnt able to get the hub apart from the strut and so gave up nd put the car back together, but after starting the car the ABS and ESR light comes on and the dash screen says ABS fault and ABS/ESR not functioning... I thought at first it may just be a faulty sensor so replaced this (at a cost of £50 from pug) and its still coming up with the fault.. the brakes work perfectly fine tho other then the warning light coming up.. any ideas??
any help would be much appreciated.. cheers Very Happy
richpowell91
PostPosted: Sun Oct 07, 2012 4:07 pm Up
Have you had the codes read to see what that suggests?
PostPosted: Sun Oct 07, 2012 7:52 pm Up
Checked you haven't cracked the abs ring?
Big_Rich180
PostPosted: Mon Oct 08, 2012 3:52 am Up
What She Said
I had 3 go on my 180...bags of s**t Laughing
Schumi
PostPosted: Mon Oct 08, 2012 6:00 am Up
Battery ?
2005 206 RC RED
Big_Rich180
PostPosted: Mon Oct 08, 2012 7:09 am Up
Schumi wrote:
Battery ?
It would normally throw other faults as well if it was the battery wouldn't it?
dafatkid88
PostPosted: Mon Oct 08, 2012 8:10 am Up
Its Not The Battery..Am Gonna Try Get It Hooked Up To A Code Checker ASAP... nd Am Gonna Make Myself Sound Really Stupid Now lol.. But Where Abouts Is The ABS Ring Located? As I Think That Could Well Be A Possibilty.. Cheers For The Feedback Guys.. Much Appreciated Very Happy
PostPosted: Mon Oct 08, 2012 8:12 am Up
on the driveshaft, it got tooth on the outer edge
dafatkid88
PostPosted: Mon Oct 08, 2012 8:27 am Up
Oh Yeah... I Know The Bit Youre On About.. What Ya Reckon Could Be Wrong There If Anything? A Missing Tooth or Something Like That I Guess?
GTi180 - FOX 17" Gloss White Rims, FK-AK Coilovers, Powerflow Stainless Steel Cat Back, Limo Tints, Morettes, Badgless Grill
PostPosted: Mon Oct 08, 2012 8:45 am Up
There very common to crack.
Big_Rich180
PostPosted: Mon Oct 08, 2012 9:04 am Up
As Lee said its most likely cracked, they're made out of jelly lol.
Danielpates
PostPosted: Mon Oct 08, 2012 12:55 pm Up
have you checked the fuse because had the same problem and when had the codes read it was steering angle sensor no signal so checked the fuse and it had blown so changef that and been ok since
dafatkid88
PostPosted: Fri Oct 19, 2012 3:18 pm Up
Any Idea What Fuse Number It Was Dude? Cheers
Danielpates
PostPosted: Sat Oct 20, 2012 4:49 am Up
I can't remember tbh mate but i know it's a ten amp one inside the drivers footwell
PostPosted: Sat Oct 20, 2012 5:18 am Up
RTFM
public.servicebox.peugeot.com/ddb/
Fuse lists are on the forum to if you bother to look for them.
