Latest: TigerHunters
Overall: 17144
Online Now [58]:
Visitors: 57
Today: 10103
Total: 115883366
Project sleeper
Go to page Previous  1, 2, 3 ... 57, 58, 59 ... 85, 86, 87  Next
PostPosted: Fri Sep 21, 2012 3:14 pm Up
Just looked at my top hose that goes to the radiator as standard it bends upwards and I was just going to turn it 180 degrees to bend downwards. However if I just get a straight length of hose from thermostat it will fit perfectly with the height of my new radiator. Nice and simple.
spike_202
PostPosted: Sun Sep 23, 2012 9:03 am Up
That's what they did with mine. You don't want your rad to low or it will be lOwer than your bumper
**spike's project**
TEAM:+200bhp
PostPosted: Mon Sep 24, 2012 3:30 pm Up
Bit more spending today. Decided I didn't like the play in the belt tensioner bearing. So I bought a new tensioner...of course it will be fitted with some new bolts too!
PostPosted: Sat Sep 29, 2012 10:08 am Up
Decided to made a cardboard radiator today. It's not too good at holding water though. As soon as I know how deep Radtecs dual core radiators are I'm going to make a dummy out of hardboard or thin plywood.
Then I'll get all the measurements exactly as the final version will be and will probably trim the old rad housing a bit more. Once I have my wooden radiator it can then be fitted with all mounts in place to make sure it doesnt foul anything. I think I'll be able to re-use the original upper radiator mounts and hoses too.
I also need my new air filter before I trim any more off the remains of the slam panel. I just hope it's strong enough once it's trimmed.
Should be enough room at the front for one or two fans.
PostPosted: Fri Oct 05, 2012 8:28 am Up
Order my ITG Sausage filter and backplate from MotorsportWorld yesterday...another £144. Will take about a week to make it. The 125mm internal depth filters are made to order.
A few little tweeks today...well I put some of it back together...all in the name of attention to detail.
New bolts for the tensioner.
New bolts for the sump...
Old bolts...
New bolts...
All fitted back together...
spike_202
PostPosted: Fri Oct 05, 2012 2:58 pm Up
What flow rate filter did you order? Road or competition use?
**spike's project**
TEAM:+200bhp
PostPosted: Fri Oct 05, 2012 4:36 pm Up
I ordered a Megaflow filter which is capable of flowing about 3 times as much air as my engine will consume.
What you think about this??? Use the original air conditioning pump mounts on the engine block and sump to fit the Saxo/106 steering pump to....will need a mount fabricating but it's solid and keeps the weight nice and low.
Hoses will be nice and short and also means no drillling of bodywork.
spike_202
PostPosted: Sat Oct 06, 2012 2:53 am Up
It's up to you were you fit it Paul, fitted mine in the same place the 106 has Thers fitted so it was a direct fit using the rubber mounted bracket that comes with it. Also it's accessible if you need to change/top up the pas fluid it's only like 3holes you have to drill iirc But be different and do it your way Wink
**spike's project**
TEAM:+200bhp
PostPosted: Sat Oct 06, 2012 4:03 am Up
It might not even fit under the alternator and oil filter but I shall see. Not sure how it would like the vibration from the engine either. Some rubber in the mounts would be useful. I'll see if it fits when I buy one. I just don't like drilling bodywork!
I'd like to see how the electric pump fits on the 206 1.6 HDi.
PostPosted: Wed Oct 10, 2012 3:57 pm Up
Filter has arrive today. Cut the back plate to fit. Just needs a Dremel to cut away the burrs from drilling it.
Next step is the Saxo PAS pump and then I'll know what space the radiator car fill.
PostPosted: Wed Oct 10, 2012 4:18 pm Up
Still great progress mate, one day you never know she might be complete Wink
Good to see the attention to detail is still there, but on the subject of power steering pumps, i only did my conversion because i felt the original looked quite ugly.....
PostPosted: Thu Oct 11, 2012 12:50 am Up
Ugly? Well that could be said yes. The electric pump is also an opportunity to fit some nice braided hydraulic hoses too...
JamieM
PostPosted: Thu Oct 11, 2012 4:43 am Up
Looks awesome Smile
When you've put it all back together get some videos of it in action please lol
Aegean Blue 206 GTi180
PostPosted: Fri Oct 12, 2012 4:37 pm Up
Trimmed the remains of the radiator housing a bit today to fit round the air filter. Still needs another 5mm removing to give more room for the engine to move on its mounts.
I'm just keeping the slam panel to support the grille and provide a secure lock for the bonnet. I wouldnt think what's left is strong enough to secure the bonnet when driving.
usher
PostPosted: Fri Oct 12, 2012 4:44 pm Up
looking good, how long till you get your rad sorted?
you expecting much from the longer trumpets or just a little smoother power?
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Page 58 of 87
