Latest: dreyfalon
Overall: 17121
Online Now [564]:
Visitors: 563
Today: 63021
Total: 97589318
Forums › The Car › 206 Problems › Spare wheel cage
Spare wheel cage
Yossarian
PostPosted: Sun Oct 14, 2012 6:19 am Up
Just had my spare wheel cage fall down going over a speed bump, got a hell of a fright with the noise. The bolt with the clip came right off! I put it all back on and tightened it up and it seems ok now. Anything else I should do or watch out for? I dont want this happening again.
PostPosted: Sun Oct 14, 2012 7:01 am Up
The bolt has been known to unscrew itself from the clip.
Try adding some cable ties to the wheel carrier then to the metal bumper brackets or similar.
PostPosted: Sun Oct 14, 2012 9:22 am Up
Seen a 405 spare wheel cage come undone by itself back in 1989 Laughing
I've never had one come undone on anything PSA ive owned / driven over the last 15 years Cool
As for the bolt unscrewing itself, I bet 80% of the 206's on here with a spare cage the bolt is actually rusted up making the spare wheel useless Laughing
PostPosted: Sun Oct 14, 2012 9:57 am Up
I put copper grease on mine to avoid it seizing...it also helped it gradually unscrew itself. It never got far because I checked it regularly. Before long the wheel lived in the boot - keeps it in much better condition.
Yossarian
PostPosted: Sun Oct 14, 2012 10:23 am Up
Yeah mine is pretty greasy. I did think the cage was a bit low as I could see the wheel from behind I just didnt get round to tightening it. I may stick some cable ties on too just to make sure.
Cheers guys
PostPosted: Sun Oct 14, 2012 10:30 am Up
Or just chuck the wheel in the boot where it stays in better condition (tie it down though so it's secure) and bin the cradle.
