Posted: Tue Oct 16, 2012 8:22 am |
I recently bought yet another Peugeot 206 1.4 LX (2001) as a home project to learn how to repair and service cars (novice home mechanic) and have noticed the following.
The engine temp gauge never goes above 1/5th. In otherwords, it always stays cool. This is even after a good run and then letting the engine idle for 20 minutes immediately after.
I can understand the gauge staying quite cool when at speed, but even then it seems a little too low. It does move, but as I said, not very far.
What I am concerned with is that the coolant is not being injected at the correct time and that the engine might get damaged if it begins to get too hot.
1. Are there failsafe sensors to detect this type of problem?
2. If there are fail points that could cause this, what tests can I perform to identify possible issues.
3. AOI - any other ideas..
There are no faults being reported from my OBD reader.
Thanks!
SR
Posted: Tue Oct 16, 2012 9:35 am |
sounds like your thermostat has been taken out for some reason
| Tripple P\'s......PURE PUG POWER | |
Posted: Tue Oct 16, 2012 9:59 am |
Hmm, ok. I am not sure about that, but I will check tonight when I get home. Worth a look. Might be that it needs replacing. They are pretty cheap so I might replace it if I can't find anything else wrong.
Thanks,
SR
Posted: Tue Oct 16, 2012 1:24 pm |
Check with PP2000 for the engine temp reading.
2001 1.4i will be non-mux and has seperate sensor and circuit for the gauge.
It's very inaccurate -/+ 10 C and the gauge motor itself could be up the creek too.
It usually is thermostat though so check that first.
Posted: Tue Oct 16, 2012 1:26 pm |
I did temp sensor on mine & then found the thermostat was faulty to so had to change that aswell
Posted: Tue Oct 16, 2012 2:17 pm |
Start car from cold.
Allow to warm on idle regularly checking top hose temp by hand.
If it warms gradually the stat is stuck open or not fitted.
If it gets hot suddenly the stat exists and is opening at a set temp.
However, stats get weak with age and often open early.
They are cheap - just change it (especially now winter is approaching) and get 2-3 more mpg.
Posted: Tue Oct 16, 2012 2:19 pm |
V9977 where do you get PP. I have looked everywhere and either the links don't work or it is expensive.
Posted: Tue Oct 16, 2012 2:22 pm |
You can use a multimeter IF it has temp function on it OR use a infra red thermometer if you have either of these in your tool box.
Posted: Tue Oct 16, 2012 6:22 pm |
kandlbarrett wrote: |
V9977 where do you get PP. I have looked everywhere and either the links don't work or it is expensive. |
Posted: Wed Oct 17, 2012 9:57 am |
The Peugeot Planet / Citroen Lexia software isnt actually a problem as you can download it FREE if you know where to look, its the correct Planet / Lexia diagnostic leads that cost the money & you cant install the software without the lead.
Posted: Wed Oct 17, 2012 12:54 pm |
Trade Rating: -1
You should be happy, At least your cars not over heating, not that you'd know if it did!!
Posted: Sat Oct 20, 2012 6:25 am |
MrBSI wrote: |
The Peugeot Planet / Citroen Lexia software isnt actually a problem as you can download it FREE if you know where to look, its the correct Planet / Lexia diagnostic leads that cost the money & you cant install the software without the lead. |
I've never seen an interface come without the software.
Posted: Sat Oct 20, 2012 9:32 am |
V9977 wrote: |
MrBSI wrote: |
I've never seen an interface come without the software. |
I've got the software, just no interface YET
Posted: Sat Oct 20, 2012 11:12 am |
Try aliexpress.com ... and search for pp2000 ... I got one for £62.19 inc del from HK back in March. depends a lot on the exchange rate.
Posted: Tue Oct 23, 2012 2:20 am |
My new thermostat should be arriving today, but I have just noticed something else odd happen. The gauge stays very low like I said, but today on the way to work, the temperature gauge suddenly flew into the red out of nowhere and I read off code P0115 from the OBD.
I didn't think the two components were linked with regards to their individual circuit. Functionally, sure. Could this now mean that the coolant sensor is faulty also? Seems a bit of a coincidence.
My cooling fan doesn't come on, but I have assumed that is because of the thermostat probably being stuck open.
Could the thermostat have suddenly stuck closed? I didn't notice the fan coming on either so I am not sure about this.
I am also starting to suspect the earth, as I am sure there could be some corrosion in this old baby.
So, to summarise, here are my problems:
1. Gauge stays very low (except suddenly this morning as I was pulling into work)
2. Fan never comes on
3. After about 35 miles the performance is a little erratic
4. Today, the gauge flew into the red and car logged a P0115
(the engine didn't seem abnormally hot)
Any ideas as to where I should focus?
I am planning on seeing how the car is after I have replaced the thermostat but if I should check things asap then suggestions would be cool (excuse the pun).
