Latest: ArtistKS
Overall: 17145
Online Now [331]:
Visitors: 330
Today: 27862
Total: 116121008
Forums › The Car › 206 Problems › replacing front wheel hub
Sim
PostPosted: Thu Oct 25, 2012 4:40 am Up
Hello,
Considering the wheel wobble ( www.youtube.com/watch?v=8yiQ0U50WdU ), I have second guess: CV joint should eliminate all wobble originating between itself and transmission. (before you ask: the wheel has no play whilst moving it by hands, and wheel itself is fine, as I swapped them and when wheel off, can see brand new brake disk touching pads as it spins - you can hear brakes squeek intermittently when hot and at low speeds)
So you might be right: wheel's hub flange is uneven/warped/hit/races borked,
Please tell me how hard it is to replace a hub (the whole or the flange only):
* Should I replace it on both axles?
* What does the "outer diameter" dimension mean?
* Why does e-bay offer to buy the whole hub (2nd hand), but new parts are offering only a flange? : www.ebay.co.uk/sch/Sus...+wheel+hub
In contrast to (says it fits for my Pug, but dimensions differ by mm):
www.ebay.co.uk/itm/FRO...7b7&_uhb=1
and
www.ebay.co.uk/itm/Fro...cae&_uhb=1
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Thu Oct 25, 2012 9:15 am Up
because most breaker can't be bother to remove the hubs from the front pivot (and most likely when you pull out the hubs the bearing will be destroyed)
Sim
PostPosted: Thu Oct 25, 2012 10:16 am Up
Thanks Seabook;
I'll try swapping the front hubs together, see if wobble gets swapped as well.
Any pointers to look out for while dismantling? (e.g. I haven't got a torque wrench)
Cheers,
EV (roadtripper)
GTC VXR (sold)
PostPosted: Thu Oct 25, 2012 10:40 am Up
well you need a hubs puller to remove the hubs...
and you need a press to fit new bearing and remove the old bearing
Sim
PostPosted: Thu Oct 25, 2012 11:16 am Up
wont it come off by hand?
at this stage i will not remove bearings, but thanks for future
EV (roadtripper)
GTC VXR (sold)
PostPosted: Thu Oct 25, 2012 11:36 am Up
not a chances, unless you can pull out 10 tonnes of power
Sim
PostPosted: Thu Oct 25, 2012 11:56 am Up
Doesnt drive shaft just slide into the hub the same way it slides into the tranny?
EV (roadtripper)
GTC VXR (sold)
PostPosted: Thu Oct 25, 2012 1:28 pm Up
yes it is.
but the hubs are press onto the pivot.
Sim
PostPosted: Sat Oct 27, 2012 12:07 pm Up
Just did all that.. no luck Sad read on (the original problem thread): www.206info.co.uk/Foru...47088.html
sorry for cross post
EV (roadtripper)
GTC VXR (sold)
