Latest: elelectricistadeMateo
Overall: 17127
Online Now [52]:
Visitors: 50
Members: 1
Today: 20816
Total: 100393501
Forums › The Car › 206 Problems › Squeaking clutch pedal
lulalou
PostPosted: Thu Oct 25, 2012 1:14 pm Up
I have a 206 1.4, recently the clutch pedal has started to make a slight squeak when depressed, it's coming from inside the car not outside. I haven't noticed any problems with the clutch all seems fine, no other noises or problems changing gear etc. Been told by the garage that I need a new clutch as the thrust bearing is failing this is based on the mechanic hearing the squeak when test driving the car for another issue. Do I need a new clutch or is it likely to be just the pedal? Cars done 64000 and is a 55 plate. Any advice appreciated Very Happy
kenzie
PostPosted: Thu Oct 25, 2012 1:17 pm Up
Mine sounds like it does the same as yours its just the peda. Mine has done it for a bit won't do any damage just try squirt some wd40 on the top of the pedal
Red 206 GTi
Revenge is like a ghost. It takes over every man it touches. It's thirst cannot be quenched, until the last man standing has fallen. The world's men of action will look and wonder...how it came to this. You may be able to destroy me, but the beast will eventually come for you
lulalou
PostPosted: Thu Oct 25, 2012 3:12 pm Up
Just a bit concerned that if it is the clutch and I carry on using the car it will cause more damage?
PostPosted: Sun Oct 28, 2012 4:46 pm Up
Probably just the point that the pedal pivots on. Shouldn't cause any damage to the clutch at all. Mention it at the next service and it should be a very cheap fix.
southwestchap
PostPosted: Mon Oct 29, 2012 4:17 am Up
WD40 the top of the pedal where it pivots, i had this the other day on mine.
