Latest: tc.206
Overall: 17147
Online Now [58]:
Visitors: 57
Today: 2917
Total: 116316525
Project sleeper
Go to page Previous  1, 2, 3 ... 58, 59, 60 ... 85, 86, 87  Next
PostPosted: Sat Oct 13, 2012 1:53 am Up
I'm going to get the new power steering pump fitted in the next month, that will show me what space I have for the radiator.
The longer inlet shouldnt do any harm. Apparently correct inlet length can have a significant affect on the power delivery.
PostPosted: Tue Oct 23, 2012 2:25 pm Up
Steering pump arrived today. Needs a bracket to mount it and the cap is damaged so I need to soucre a new one. They don't seem to be available as a part on their own. If anybody knows where I can get one let me know.
Arrived a bit dirty...
A bit cleaner now. I also fitted the remains of the original 206 pressure hose from the old pump.
usher
PostPosted: Tue Oct 23, 2012 4:18 pm Up
looking much better now its clean,
is that rusty tools i see aka well used lol
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Tue Oct 23, 2012 4:22 pm Up
That's my 14 year old Halfords socket set. Just the imperial sockets have light corrosion on the inside of them!
spike_202
Same pump as mine mate, when you do the loom, fuse it before and after the relay as they draw a hi current. You'll need the bracket that should of come with it off a 106 as it's got rubber mounts to stop it vibrating.
**spike's project**
TEAM:+200bhp
PostPosted: Wed Oct 24, 2012 7:01 am Up
Yes the clips round the pump have the rubber on it. Is there any difference between Saxo and 106 pumps and brackets? I think the Peugeot bracket might be slightly cheaper.
I notice the current draw when I tested it yesterday. To make sure it worked one thick cable and a thinner one direct to the battery resulted in the thin cable getting quite warm!
It also needs a new cap and I'm hoping the caps are the same as the cars with a seperate reservoir as you can but new caps for those types.
You got any clear pictures of your bracket? I'm thinking it might need to be attached partly to the original airbox braket for extra support at the side.
spike_202
PostPosted: Wed Oct 24, 2012 12:39 pm Up
I haven't mate I'll get some at the weekend for you it's sort of at a L shape so fits in the corner by the old air box at the bottom of the metal work were the abs pump is sitting on think they used 10mm cable for the loom
**spike's project**
TEAM:+200bhp
PostPosted: Wed Oct 24, 2012 1:33 pm Up
Just looked at your picture from a couple of pages back. I can see how it's mounted. Your crossmember has definately been cut to fit that radiator.
spike_202
PostPosted: Wed Oct 24, 2012 7:15 pm Up
I no, as I wanted it pushed forward and down so I had as much clearance as possible for the fan and the air flow to the inlet it doesn't go lower than the bumper so it's not a problem. You also need the room to mount the pump were I have mine
**spike's project**
TEAM:+200bhp
usher
PostPosted: Thu Oct 25, 2012 1:34 pm Up
thats doing quite well then considdering, my bits have competley rusted now only a few years old, all tools get cleaned after each use Smile
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Thu Oct 25, 2012 2:16 pm Up
Also as you can see, some of the bigger imperial socket are like new. They do get damp occasionally when it starts to rain and I'm using them outside. They do get looked after though.
You need to use the tools a bit more, that will keep the rust off them!
PostPosted: Mon Nov 05, 2012 3:15 pm Up
More goodies arrived today. Nyloc nuts and bolts to mount the steering pump bracket which should arrive this week. Also ordered stainless steel OMP bonnet pins. Decided on these because they just need simple holes drilling to fit them.
Ordered it from Demon Tweeks on Friday afternoon and it arrive by this morning. Not a bad price either at £21.75 delivered.
spike_202
PostPosted: Mon Nov 05, 2012 4:52 pm Up
IMO mate your Gunna reck the look of your car if you fit them pins. they look gash they look ok on track car that's batterd and not in mint condition, I thought you were Gunna go a different direction to what I've done? As you found away to mount the bonnet catch?
**spike's project**
TEAM:+200bhp
PostPosted: Tue Nov 06, 2012 1:56 am Up
The catches are small and will work perfectly. They are far easier to fit than Aerocatches too.
I'm binning the bonnet catch and the release lever and cable. Going to buy an aftermarket bonnet alarm switch to replace the original.
Keeping some of the original slam panel just to support the front grille.
spike_202
PostPosted: Tue Nov 06, 2012 2:30 am Up
Lol fair enuf mate. I knew you would end up using pins as it's the only way of doing it so you get a good air flow with out blocking the intake I personsly wanted pins as they look cool aswell as do the job.
**spike's project**
TEAM:+200bhp
Page 59 of 87
