Posted: Thu Oct 25, 2012 9:56 am |
So id been putting off this for a few months but as an oil change was due it made sense. It was the suspect oil filter housing seal which had perrished. All in it cost me £78 which im happy with
Posted: Thu Oct 25, 2012 1:06 pm |
Was that at a dealer?!
Posted: Thu Oct 25, 2012 1:14 pm |
Local garage
Posted: Thu Oct 25, 2012 1:20 pm |
Quite expensive for an oil change, but thats garage prices i suppose! At least you got your problem solved.
Posted: Thu Oct 25, 2012 2:19 pm |
Does seem very expensive.
Posted: Thu Oct 25, 2012 4:27 pm |
It wasnt for just an oil change as i said in my post. The oil filter housing needed removing and the inner seal replacing
Posted: Thu Oct 25, 2012 4:33 pm |
Thats very cheap
The inlet has to be removed, but the seal is only about £2 or so
| Team Impossible Possible
