Latest: eltel666
Overall: 17146
Online Now [109]:
Visitors: 108
Today: 12546
Total: 116149579
Forums › The Car › 206 Problems › New debadged front grill and bonnet vent painting advice
Tolkienfan001
PostPosted: Sat Oct 27, 2012 2:28 am Up
Trade Rating: +13
Hi all,
I am collecting a new debadged grile and bonnet vent. They will need to be painted before fitting.
Is this something I could do myself?
If so what materials should I use? What are the common mistakes to avoid?
My paint code is EZR Aluminium.
2005 1.4 16v Sport
Check out my 206 here!
anton1989
PostPosted: Sat Oct 27, 2012 4:46 am Up
Trade Rating: +16
Im sure there are a few topics on painting somwhere.
You can do it yourself, you can do anything yourself if you have the confidence
Of the top of my head you need
Sand paper in various grits
Plastic primer
Paint in your colour code
Lacquer
I would get a few quotes frm a body shop as it wont be far off what its going to cost to do yourself, especialy if you make mistakes
Hope this helps
roscoe
PostPosted: Sat Oct 27, 2012 4:58 am Up
Hi, bonnet vent will fit straight on. SP or standard simple replacement no need for any painting.
The debadged grill on the other hand will need to be primed, painted and laquered.
I recommend a quote of a professional if your unsure.
I done half my front bumper myself a while ago. I had the same colour 206 as you. Just went to halfrauds bought the EZR spray, wilkinson's for the clear laquer and primer and took my time. Pretty good job too couldn't tell. I've got an old post somewhere I think.
If it was me I'd get a quote off a pro.
Used to own the 206 pictured above
M sport BMW E90 - Gone Sad
Now own Audi A5 Sline Smile
PostPosted: Sat Oct 27, 2012 5:28 am Up
If they don't come supplied, get some clips from your local Peugeot dealer. 9 times out of 10 you will break one of the clips on the grill/ The ones on the bonnet vent are pigs to get out in one piece so you will need four of these.
781324 Bonnet Vent Rivets 37p each
6995X3 Grill clips 26p each
I painted the bonnet vent over summer. lightly key the surface using scotchbrite. As anton says, plastic primer, base colour and lacquer. Wet n dry paper for finishing. Small tin of paint thinner for degreasing before applying the primer. A warm room is helpful otherwise moisture in the air can affect the finish. Time and patience is the key. Rush it and it will look a mess. With the right tools and equipment it can easily be done in a few hours. If first time spraying and in a garden shed/garage, I'd allow a couple of days. Halfords paint rarely matches. Try a local supplier or online supplier who can put the paint in an aerosol for you. Usually better colour match and can work out cheaper than going to Halfords. I used Auto Paint. Took 2 days to be delivered and was a spot on match.
Take pictures of your progress at various stages and then do a thread to help others out.
Tolkienfan001
PostPosted: Sat Oct 27, 2012 6:15 am Up
Trade Rating: +13
Thank you all this is really good info. The bonnet vent is one of those body shaped ones not the honeycomb grill. I might give that a go and see how it turns out.
Thanks for the tip on the halfords paint not fully matching and the clips. That will save me a lot of stress!
2005 1.4 16v Sport
Tolkienfan001
PostPosted: Sat Oct 27, 2012 1:10 pm Up
Trade Rating: +13
Guys just wondering how much should I expect to pay if I go down the pro paint route? Don't want to get ripped off.
2005 1.4 16v Sport
