Posted: Thu Oct 25, 2012 1:14 pm |
I have a 206 1.4, recently the clutch pedal has started to make a slight squeak when depressed, it's coming from inside the car not outside. I haven't noticed any problems with the clutch all seems fine, no other noises or problems changing gear etc. Been told by the garage that I need a new clutch as the thrust bearing is failing this is based on the mechanic hearing the squeak when test driving the car for another issue. Do I need a new clutch or is it likely to be just the pedal? Cars done 64000 and is a 55 plate. Any advice appreciated
Posted: Thu Oct 25, 2012 1:17 pm |
Mine sounds like it does the same as yours its just the peda. Mine has done it for a bit won't do any damage just try squirt some wd40 on the top of the pedal
Posted: Thu Oct 25, 2012 3:12 pm |
Just a bit concerned that if it is the clutch and I carry on using the car it will cause more damage?
Posted: Sun Oct 28, 2012 4:46 pm |
Probably just the point that the pedal pivots on. Shouldn't cause any damage to the clutch at all. Mention it at the next service and it should be a very cheap fix.
Posted: Mon Oct 29, 2012 4:17 am |
WD40 the top of the pedal where it pivots, i had this the other day on mine.
