Posted: Tue Oct 23, 2012 4:10 pm |
Anyone know what sized socket I need to remove hub nut on GTi?
Cheers
| 2001 206 Gti - Original & Unmolested
1994 Renault 5 - Production Car Trials | |
Posted: Tue Oct 23, 2012 4:47 pm |
Could be 32 or 35mm
| Team Impossible Possible
Posted: Tue Oct 23, 2012 4:50 pm |
Its not 32mm, bigger than that. 34mm been suggested on another thread....?
Posted: Tue Oct 23, 2012 5:37 pm |
35mm
or you could just measure it..... isn't that easier and quicker?
Posted: Tue Oct 30, 2012 5:10 pm |
Measured it at 35mm - Bought a 35mm impact socket and used it with impact gun. Came straight off with the gun. Socket felt a little loose and still not sure its not a 34mm nut??
Posted: Tue Oct 30, 2012 5:16 pm |
well if you measure it and it said 35 how can it be 34?
Posted: Tue Oct 30, 2012 5:25 pm |
Job to measure with a tape as shaft thru centre of nut prevents you from getting tape close to nut for measuring. 35mm fits but a little play so now thinking it may be 34mm. Didn't matter in end as impact gun removed in 2 secs without having to strap up hub to stop it spinning
Posted: Tue Oct 30, 2012 5:35 pm |
Deffo a 35mm on my 180. 34 wasnt anywhere near fitting when i tried guessing first time lol.
Posted: Tue Oct 30, 2012 5:42 pm |
it's all up to you whether you believe is 35mm or not
i use 35mm socket, Dan (above) agree with me, addaz (future master tech in pug dealership) also said 35mm, plus you did use 35mm socket to remove the nut
Posted: Tue Oct 30, 2012 5:53 pm |
No axe to grind, 35mm worked for me as i said, but it wasn't a tight fit. Just sayin
Posted: Tue Oct 30, 2012 5:55 pm |
not surprise, either of mine is tight fit.
since they are not reusable i wouldn't worry too much
Posted: Wed Oct 31, 2012 10:31 am |
Seabook wrote: |
addaz (future master tech in pug dealership) |
Also means access to the Peugeot master tech forum
Posted: Wed Oct 31, 2012 1:28 pm |
My Sealey socket is a 35mm..
Posted: Wed Oct 31, 2012 3:23 pm |
MrBSI wrote: |
Seabook wrote: |
Also means access to the Peugeot master tech forum |
Ahhh the site i cant access yet, one day
Thanks though mate, hopefully one day that will be the case
