Latest: heikkisj
Overall: 17126
Online Now [61]:
Visitors: 60
Today: 9703
Total: 100382452
Forums › The Car › 206 Problems › Clock issue
Clock issue
Baggiesfan01
PostPosted: Wed Oct 31, 2012 12:37 pm Up
The clock as in the one by the hazard light button on my 2000 206 has played up since i got it 5 months ago. it works as in it has the right time just is dim. i tried a different new bulb in it still the same.
Bought a new clock of Ebay just fitted it and it's exactly the same. wondering if anyone had a similar problem? or any ideas.
Pug 2.0 HDI owner
Nosvartu
PostPosted: Wed Oct 31, 2012 1:32 pm Up
Could it be a fuse on its way out?, bad connection? might be worth checking the cable and fuses.
Newby
PostPosted: Wed Oct 31, 2012 6:45 pm Up
It's supposed to go dim when you switch the side-lights on.
Does it look the right brightness at night?
If so, could be an issue with the left stalk as it controls the brightness I believe.
Baggiesfan01
PostPosted: Sun Nov 04, 2012 6:38 am Up
it wasn't on at all unless you used a torch then you could see right time. issue solved now anyway turned out it just needed a bulb.
Pug 2.0 HDI owner
