Latest: Makomeister18274
Overall: 17122
Online Now [37]:
Visitors: 36
Today: 10650
Total: 97758605
Forums › The Car › 206 Talk › GTi Rear axle Fixings
Mounty
PostPosted: Wed Oct 31, 2012 3:46 pm Up
Have decided to bite the bullet and put a recon axle on the GTi.
Does anyone know what fitting I need to remove the 4 star shaped bolts where axle is mounted. Look like approx. 13mm in size but need to know where to get the correct bit and what size to use??
Cheers
2001 206 Gti - Original & Unmolested
1994 Renault 5 - Production Car Trials
PostPosted: Wed Oct 31, 2012 3:55 pm Up
Just go to Halfords and get a set of torx sockets.
PostPosted: Wed Oct 31, 2012 3:56 pm Up
e socket
Mounty
PostPosted: Wed Oct 31, 2012 4:03 pm Up
Yeah, thought a female torx would do it. Just wondered if anyone knew size as some fittings are a bit random and are usually the one size not included in a kit
PostPosted: Thu Nov 01, 2012 3:04 am Up
Just buy a normal set and you'll be fine.
