Latest: heikkisj
Overall: 17126
Online Now [53]:
Visitors: 52
Today: 13753
Total: 100192394
Forums › The Car › 206 Talk › Strut Brace Pics Wanted?? :)
dafatkid88
PostPosted: Fri Nov 02, 2012 4:12 pm Up
Hey Guys nd Gals!!
As My Topic Title Says.. Im After Some Pics Of Anyones Strut Braces In Their 206??
I Really Want To Get One As From Previous Car Experience I Know They Can Really Make A Difference To The Handling/Feel.. But Im Curious As To How It Fits In & Looks!
Thanks In Advance Peeps! Very Happy
PostPosted: Fri Nov 02, 2012 4:40 pm Up
You'll be disappointed if you expect to feel a difference on a 206.
Uz
PostPosted: Fri Nov 02, 2012 5:38 pm Up
^^ as Edward says. Purely for looks on the 206 due to how the engine is setup on a subframe.
PostPosted: Fri Nov 02, 2012 5:41 pm Up
Engine doesn't sit on a subframe. Lower mount uses the subframe but that's nothing to do with it.
marc206
PostPosted: Fri Nov 02, 2012 5:48 pm Up
they just look nice on a 206 Wink
Uz
PostPosted: Fri Nov 02, 2012 6:19 pm Up
Apologises I missed a few words. I meant engine bay and how the 206 has a subframe as apposed to other cars like my 106 Rallye which didn't have a subframe and the upper and lower strut braces improved the handling of the car.
drunknmunky
PostPosted: Fri Nov 02, 2012 7:14 pm Up
drunknmunky
PostPosted: Fri Nov 02, 2012 7:17 pm Up
drunknmunky
PostPosted: Fri Nov 02, 2012 7:22 pm Up
There's a few for you also got some when it was white aswell and so you know that's the omp one and fitted to a gti 180 it requires some cutting of the metal on the pollen filter side
JamieM
PostPosted: Fri Nov 02, 2012 7:51 pm Up
www.maxrevs.co.uk/cars...tleId=1815
On iPhone so can't copy links from twitter so found my old 180 on some battle site haha
Aegean Blue 206 GTi180
spike_202
PostPosted: Sat Nov 03, 2012 4:15 am Up
as above they are just astheticaly pleasing 2bh worth £30-£40 ish
**spike's project**
TEAM:+200bhp
PostPosted: Sat Nov 03, 2012 4:21 am Up
Here my pointless modification. Might be of some use if the bar was welded to the car rather than bolted to it using 3mm thick steel.
dafatkid88
PostPosted: Sat Nov 03, 2012 8:23 am Up
I Get The Hint That They Might Just Actually Do Nothing Then Guys!!? lol
Cheers For The Feedback.. When I've Got A Few Spare Quid Then I Might Still Get One As From Looking At Everyones Pics They Do Add A Nice Touch To The Bay Cosmetic Wise Smile
Bit of A Pain To Fit By The Sounds Tho
GTi180 - FOX 17" Gloss White Rims, FK-AK Coilovers, Powerflow Stainless Steel Cat Back, Limo Tints, Morettes, Badgless Grill
JamieM
PostPosted: Sat Nov 03, 2012 8:38 am Up
Not on my phone now Smile
When fitting once you have drilled the whole and cut it out grease it or paint it and put a ruber seal around it to stop it rusting that's what I did.
L5_UKS
PostPosted: Sat Nov 03, 2012 10:43 am Up
On my old 180..
