Online Now [785]:
Visitors: 784
Today: 142541
Total: 154949541
Forums › The Car › 206 Problems › Power steering leak
Power steering leak
pianoman
PostPosted: Sat Nov 03, 2012 6:29 am Up
I have a low pressure leak dripping from the bottom area of the radiator (left hand side looking fron the front).
I have not recently done much vehicle diy but fancy sorting it myself but can't find a detailed view of this area in my manual.
Does anyone know of a manual which looks at this area as I prefer not to do it blind, if at all possible.
ukskater01
PostPosted: Sat Nov 03, 2012 6:51 am Up
I would of thought a haynes manual would have all you need, I haven't got mine with me to look at but I'm pretty sure it will have pictures for when changing the fluid so will show you everything you need to look at
pianoman
PostPosted: Sat Nov 03, 2012 9:26 am Up
Thanks but I checked that and I am afraid that it doesn't show it plus I contacted one of the emanual publishers and they also do not show it -but thanks for the reply
Sim
PostPosted: Sat Nov 03, 2012 10:11 am Up
If you look from power steering reservoir the hose goes downwards and then meets a junction with another through a steel cable tie.
My one got buckled and started leaking/dropping, fixing involved replacing with a new steel cable tie.
If your's the same problem, when fixing watch out the hoses do not detach or liquid will spill all around.
Good luck!
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
pianoman
PostPosted: Sat Nov 03, 2012 10:48 am Up
Many thanks.I'll have a go as soon as the weather lets me!
PostPosted: Sat Nov 03, 2012 12:00 pm Up
What car is it?
pianoman
PostPosted: Mon Nov 05, 2012 2:19 pm Up
Hi
Sorry to be a bit late replying.It's a 1.4diesel look
Cheers
