Latest: elelectricistadeMateo
Overall: 17127
Online Now [68]:
Visitors: 67
Today: 734
Total: 100398972
Forums › The Car › 206 Problems › Intermittent EML warning
goldpug206
PostPosted: Sat Nov 03, 2012 12:19 pm Up
The car is a 2005 1.4 petrol manual.
Recently the coil pack went and then ran fine once I replaced it with a new one, except for a little bit of an eratic idle which went as low as 620 and as high as 860, this settled down and it hovered ever so slightly around 750.
Recently the engine management light has been coming on intermittently and when it does it has a slight misfire and is underpowered. I took the coil pack back and had it replaced for another new one but no difference, i have also replaced the plugs for the recommended bosch ones, iirc.
This only happens now and then but is becoming more common, maybe twice a week.
This all seems to reset itself if i leave the car for 10 minutes and then go back, then all is well and the EML has gone out and the car runs fine.
The thing i have noticed is that this seems to only happen when the enngine gets warm, there are no other links or hints to advise of.
I will have the ecu read tomorrow for fault codes.
Could this be the MAF sensor? I have also noticed it is using more petrol at the moment.
goldie!
PostPosted: Sat Nov 03, 2012 12:51 pm Up
Does the eml flash?
iainlovatt
PostPosted: Sat Nov 03, 2012 3:10 pm Up
Sounds like my problem I had, got lee above to read code for me, but it's never came back with a positive issue, just said no problem, I just got rid of it in the end lol, Smile
(My Garage)
ukskater01
PostPosted: Sat Nov 03, 2012 4:53 pm Up
Where abouts do you live, someone on here should be able to code read your car for you
goldpug206
PostPosted: Sun Nov 11, 2012 10:23 am Up
So today i finally got around to reading the ecu.
The error code was P1336.
The live data info was as follows, hopefully it can be translated,
Calc Load 21.96%
coolant temp 85 degrees C
stft b1 -2.35% to + 4.68%
ltft b1 8.59%
map 32Kpa
engine speed 750 - 780
spark advance 4.5 to 9
I.A.T 34 degrees C
T.P.S 14.1%
air status OFF
o2sl 1112
o2s 11 0.39 - 0.5v
shrtft 12 99.21%
shrtft11 -3.13 - + 3.9%
o2s 12 0.1 - 0.7v
Advise or translation of the above would be appreciated.
goldie!
PostPosted: Sun Nov 11, 2012 10:53 am Up
Whats the VIN number?
goldpug206
PostPosted: Sun Nov 11, 2012 10:54 am Up
Is there a need for that? If i post it can it be used for illegitimate purposes?
The car is a 2005 1.4 manual.
goldie!
PostPosted: Sun Nov 11, 2012 10:55 am Up
I needed to know which engine managment system is fitted, to late now i've just lost intrest.
goldpug206
PostPosted: Sun Nov 11, 2012 11:03 am Up
What a t***er. It was a straight forward question. Go play with your toys.
Unbelievable Evil or Very Mad
goldie!
PostPosted: Sun Nov 11, 2012 11:12 am Up
Your VIN is on display to anyone who walks past your car anyway. The PM function is ideal to send information to another member when you don't want the whole world to see it..
What's the point of asking for help if you can't supply all the information needed to help diagnose the problem.
Pot and kettle spring to mind
goldpug206
PostPosted: Sun Nov 11, 2012 11:34 am Up
Is this site full of keyboard warriors? I asked a simple question and got smart a**e answer from a person who has a signature more suited to themselves and now other warrior comes on and finishes his answer with a dumb ass sentence.
goldie!
goldpug206
PostPosted: Sun Nov 11, 2012 11:35 am Up
Only reply to my question if you are genuinely going to offer assistance. keyboard warriors need not reply.
goldie!
PostPosted: Sun Nov 11, 2012 11:54 am Up
If it was a dumbass sentence then you must have understood it.
Here is some help with your fault code.
Can't answer anything about the live data because alls I know is that you drive a gold 2005 206 powered by a TU3 engine and a BVM5 transmission.
goldpug206
PostPosted: Tue Nov 13, 2012 8:48 am Up
Can you not read my last post?
Are there any grown ups on here who know what they are talking about and are willing to help others?
Or is this site over run with teenage masturbators flicking between the many ;) ;) sites on the web. All high on juvenile endorphins gained from self inflicted sexual gratification over images of men or women they would never have a chance with in real life?
Ciucur
PostPosted: Thu Nov 22, 2012 3:08 am Up
Did you manage to find the source of the problem? Mine has the EXACT same problem, I couldn't describe it better myself.
1.4 16v Black
