Forums › The Car › 206 Problems › Rear axle replacment |
Posted: Fri Nov 09, 2012 6:31 am |
Hi all, been away for a while. Hope all is well.
I've been tasked with replacing a rear axle for a friends car tomorrow.
I've removed one before a number of years ago but not swapped one.
As far as I remember its 2 or 4 bolts, brake lines and handbrake cables?
Donor axle is of the same year, non abs & drum brakes. Exactly the same as the one I'm taking off.
Am I forgetting anything?
Posted: Fri Nov 09, 2012 9:48 am |
Exhaust needs removing too. Might not be so easy if it's old and crusty.
Posted: Sat Nov 10, 2012 1:09 pm |
All done. The brake lines came off nicely for a 14 year old car!
