Latest: Wan1977
Overall: 17118
Online Now [223]:
Visitors: 222
Today: 4304
Total: 95676464
Forums › The Car › 206 Talk › Checking antifreeze level
Mounty
PostPosted: Sat Nov 10, 2012 2:22 pm Up
Tried to check amount of antifreeze in coolant tank the other day but the kinked neck below the filler cap means the guage I normally use is way to short to draw up any fluid.
Any suggestions to a guage/tester that will fit the tank opening?
2001 206 Gti - Original & Unmolested
1994 Renault 5 - Production Car Trials
fatboyslim
PostPosted: Sat Nov 10, 2012 2:55 pm Up
Could maybe try sticking a tube on the the end of your testing thingy
Yes I own a CC and I'm neither gay or a hairdresser!!
Mounty
PostPosted: Sat Nov 10, 2012 3:09 pm Up
Yeah, was thinking that too. Haven't got a bit that will fit right now but can't be too long as priming bulb only has a certain capacity of how much it will draw up standard length of tube
spike_202
PostPosted: Sat Nov 10, 2012 7:00 pm Up
Buy a decent tester then? Mine was £8 from a local motor outlet and has a nice long tube on the end.
**spike's project**
TEAM:+200bhp
PostPosted: Sat Nov 10, 2012 9:02 pm Up
those hydro-type tester is pretty useless and inaccurate.
and strictly speaking unless you keep toping it up with water, the ratio of anti-freeze to water will remain constant.
spike_202
PostPosted: Sun Nov 11, 2012 4:01 am Up
Mine seems to work spot on. get one of these, notice the long tube they sell them on eBay also
**spike's project**
TEAM:+200bhp
DanT
PostPosted: Sun Nov 11, 2012 6:06 am Up
I've got one exactly like this, sealey one iirc, i've used it for a few years now, works well enough and only cost a few quid so i'll be using it for the foreseeable future Smile
Mounty
PostPosted: Sun Nov 11, 2012 12:41 pm Up
Thats exactly like the one I've got, except the tube is only about 2" long. I reckon one of my blokes has chopped the end off for some reason. Perhaps I'll do the same to him.............
Edit: In motor spares shop today and turns out they do one with a short tube and one with a long tube. When I bought the short one it was the only one they had.
Managed to draw enough out with a LARGE syringe and a bit of fuel pipe.
