Posted: Sun Nov 11, 2012 9:03 am |
Trade Rating: +13
Posted: Sun Nov 11, 2012 9:09 am |
£55.30 for Pagid discs and pads at Euro Car Parts with the Pagid30 discount code.
Posted: Sun Nov 11, 2012 10:09 am |
Trade Rating: +13
Have you got a link? I can't find it??
Edward wrote: |
£55.30 for Pagid discs and pads at Euro Car Parts with the Pagid30 discount code. |
Does this go for their ceramic anti-squeal grease paste?
If so I need to get some.. it's the only stuff that keeps on working after 2-3 months.
Posted: Sun Nov 11, 2012 10:37 am |
Tolkienfan001 wrote: |
Have you got a link? I can't find it?? |
You can't find Euro Car Parts?
Posted: Sun Nov 11, 2012 11:50 am |
Trade Rating: +13
I can find euro car parts just not the discs and pads set. Do you buy them separately?
Posted: Mon Nov 12, 2012 6:12 am |
Just put your reg number in then seach for pads and then discs.
Posted: Mon Nov 12, 2012 2:38 pm |
is copper grease still used?
Posted: Mon Nov 12, 2012 2:58 pm |
bezford wrote: |
is copper grease still used? |
Yes I still use it
Posted: Mon Nov 12, 2012 3:05 pm |
bezford wrote: |
On the backs of pads & caliper mating surfaces = YES
On slide pins = NO as copper grease damages the rubber dust seals, use the correct brake grease on these!
Posted: Mon Nov 12, 2012 3:07 pm |
Dillon wrote: |
bezford wrote: |
Yes I still use it |
Yep. Was using this at the back of pads for years.
However in this application it stops working after a while..
I then tried Pagid ceramic paste and they've gone silent for the past 2.5 years and counting.
'Copper-ease' is still brilliant for lots of other uses though.
Posted: Wed Nov 14, 2012 7:22 am |
Trade Rating: +13
Edward wrote: |
Just put your reg number in then seach for pads and then discs. |
Thank you for your help I appreciate it!
