Online Now [1001]:
Visitors: 1000
Today: 151929
Total: 151931919
Forums › The Car › 206 Problems › Car leaking again
Car leaking again
Razor34
PostPosted: Mon Nov 12, 2012 6:31 am Up
Hi.
My wonderful Peugeot 206 1.4 GLX 02 Plate 5 Door is leaking again through the rear passenger door. I took the door card off an resealed the membrane with duct tape as well as making sure that the drain holes are clear. It seems to be trickling through the bottom of the door by window handle.
Any ideas, should I change the door rubber itself even though there seems nothing wrong. It is driving me mad at the moment as I constantly have a soggy carpet Shocked
Ray
jk206
PostPosted: Mon Nov 12, 2012 2:42 pm Up
my front passenger door leaked as there was a tiny hole in the membrane, so all i did was smear a bit of waterproof silicone over it and it sorted it!
bezford
PostPosted: Mon Nov 12, 2012 4:13 pm Up
do you have any other questions/problems your seeking answers to on here at the moment?
R.HYDE
Razor34
PostPosted: Tue Nov 13, 2012 2:21 am Up
No other questions, just this Very Happy
Ray
bezford
PostPosted: Tue Nov 13, 2012 8:35 am Up
I thought id seen u askin sumthin else and thought the problems
could have been related...
R.HYDE
Razor34
PostPosted: Thu Nov 15, 2012 2:28 am Up
Anyone else got any suggestions. Membrane seems fine.
Ray
Deckchair5
PostPosted: Thu Nov 15, 2012 8:45 am Up
As the water getting into the door is coming in faster than it can get out I'd take a look at the window glass bottom door seal between the window bottom and the door. Run a piece of folded card down between the glass and the rubber to clean up and get rid of any debris that is holding the rubber off the glass. Inspect it for any damage or kinks that would allow more water in than normal
With the door bottom drain holes, besides making sure the holes are clear, use a long cable tie to get in and along far enough to make sure they're well clear further in as they tend to go immediately into narrow channels
Finally do a test with the door open of putting a hose pipe on the window, you don't need to blast the water in but keep it on long enough so it has chance to build up inside the doors if it's going to and look for water freely coming out of the drain holes
Razor34
PostPosted: Thu Nov 15, 2012 10:16 am Up
Many thanks Deckchair5 will give it a go
Ray
