Online Now [509]:
Visitors: 508
Today: 168076
Total: 157634951
Forums › The Car › Request a how-to › Connecting h7 headlights to h4 socket using this connection
nemesislee
PostPosted: Wed Nov 14, 2012 5:57 pm Reply with quote Up
I have this connection and a set of GTI headlights on the way, can I use this to connect them up to my h4 connector? I've tried on the other forums but no one is replying
peugeot 206 silver 1.4ltr lx
PostPosted: Wed Nov 14, 2012 5:59 pm Reply with quote Up
if the little spade connectors fit onto the blubs spades then yes.
nemesislee
PostPosted: Wed Nov 14, 2012 6:04 pm Reply with quote Up
I've used this to connect a set of angel eyes (which I give up on) and both the h1s worked using it and these seem to fit onto a h7 bulb too
PostPosted: Wed Nov 14, 2012 6:07 pm Reply with quote Up
if the connectors fit to the h7 bulbs then they will work, just make a little hole in the the rear case of the lights, feed the cables in and connect them up, seal the hole bit of silicone.
red will be dipped and blue full beam iirc
nemesislee
PostPosted: Wed Nov 14, 2012 6:08 pm Reply with quote Up
Awesome Smile
nemesislee
PostPosted: Wed Nov 14, 2012 6:09 pm Reply with quote Up
Thanks very much Smile
PostPosted: Thu Nov 15, 2012 8:59 am Reply with quote Up
Why bodge like this when for less then £8 you can get the 2 x grey H7 connector plugs & the 6 terminal pins from any Peugeot / Citroen main dealer & do the job correctly Rolling Eyes
coopskin
PostPosted: Thu Nov 15, 2012 11:13 am Reply with quote Up
Trade Rating: +13
I have the required Valeo harness for this mod. Look at 206info.co.uk/Forums/v...51059.html
  Quick Reply
Username:
Message:
Quote the last message
